Results 1 to 6 of 6
    Very Active Member bluestratos's Avatar
    Jun 2011
    Lynden, WA
    Default Back rest adjustment on BRP backrest
    Someone mentioned on here that there is an adjustment for the BRP back rest under the zip on cover. I removed my cover but could find no adjustment whatsoever and from the design of it cannot imagine how they would do it. Any help with this one would be appreciated.
    Jun 2013
    queens ny
    there is no adjustment, the adjustment is on the one for the f3
    NO BIKE AT THIS TIME
    May 2015
    Barryville NY
    Default Washers
    You can put a couple of washers between the mounting bracket for the backrest and the bottom of seat. This only gives the backrest a small tilt back if you put them under the rear of the bracket.
    Very Active Member BikerDoc's Avatar
    Clermont, Florida
    Quote Originally Posted by cuznjohn View Post
    The adjustment works well on the F3, can't understand why they didn't incorporate that into the RT backrest for 2015
    220,000 Mile Spyder Ryder, IBA Premier member #59352, Saddlesore 1000 (11), Bun Burner 1500 (3), Saddlesore 2000 (2), Bun Burner Gold, MILEEATER SILVER
    Jun 2011
    Lynden, WA
    Ahhh, that explains it, thanks
    Aug 2012
    Central Coast, CA
    Quote Originally Posted by beast68 View Post
    This is a really nice modification and to me made all the difference.
    2020 RTL SE6
