Back rest adjustment on BRP backrest
Someone mentioned on here that there is an adjustment for the BRP back rest under the zip on cover. I removed my cover but could find no adjustment whatsoever and from the design of it cannot imagine how they would do it. Any help with this one would be appreciated.
Thanks
there is no adjustment, the adjustment is on the one for the f3
NO BIKE AT THIS TIME
Washers
You can put a couple of washers between the mounting bracket for the backrest and the bottom of seat. This only gives the backrest a small tilt back if you put them under the rear of the bracket.
The adjustment works well on the F3, can't understand why they didn't incorporate that into the RT backrest for 2015
220,000 Mile Spyder Ryder, IBA Premier member #59352, Saddlesore 1000 (11), Bun Burner 1500 (3), Saddlesore 2000 (2), Bun Burner Gold, MILEEATER SILVER
Ahhh, that explains it, thanks
This is a really nice modification and to me made all the difference.
2020 RTL SE6
