Results 1 to 6 of 6
    Registered Users Edsts's Avatar
    May 2013
    New jersey
    Default Pls help Brak failier
    Riding around on my sts and all of a,sudden i am getting a weird symbol like a circle in a circle , then the screen says brake failier . I pulled over for safety ,
    the brakes are working in good order , has this ever happen to any one .
    Jun 2015
    St Charles, IL
    Adding brake fluid took care of mine when that happened.
    May 2013
    New jersey
    Thumbs up
    Quote Originally Posted by ByronM View Post
    Thanks , Just wanted to know how serious , i am not close to home and don't wanna risk in getting any one hurt or even my self if i loose my brakes.
    Thanks again i love this place ,
    Default BRAKES
    Quote Originally Posted by Edsts View Post
    IMHO, the likelihood of you losing your brakes are slim.....the sensor in the Spyders is HYPER-sensitive in detecting even a very small amount of LOW fluid........make sure the cap area is clean before you open and do not add more than one teaspoon at a time......because it's easy to overfill...........Also be very careful screwing the caps back on...cross-threading will cause them/it to leak and brake fluid is close to BATTERY ACID in corrosiveness ....good luck...Mike
    Default Also...
    check that your brake switch is not sticking. Seems to a growing problem. Double think if you were ryding with your foot on the pedal. Start with the fluid...
    ​2012 RS sm5
    Active Member johnwinslow's Avatar
    Jul 2011
    Waterboro, Maine
    if topping off the brake fluid fixes it, be sure to chk the brake pads for wear, as they wear down the level of your reservoir goes down, so if you ad fluid, and then replace your pads the fluid will over flow the reservoir during the repair.
