Results 1 to 22 of 22
    Nov 2012
    Midwest United States
    Default Kenda tires for RS
    I'm replacing my RS Kenda rear tire @ 27,000, what are your experiences with Kenda tires on your RS?
    A little hx, I just put Kendas on the front. I ran 13,500 on first Kenda & 13,500 on second Kenda. I'm impressed with Kenda's ability to handle dry & wet roads. I ride solo with no saddle bags & minimal weight in frunk & as light as possible & removed heavy stock muffler.
    Thank you in advance for reading and/or responding.
    Default HUH !!!!
    Quote Originally Posted by figmotoday View Post
    If you got 27,000 miles on the rear tire of your RS Spyder ......document it and send it in to the " GUINESS BOOK OF WORLD RECORDS " because this has got to be the longest wearing Kenda rear tire ever made.......If you still have the Tire have it " BRONZED " and put it in the Kenda Tire Hall of Fame ...........PS , sorry but I don't believe you....................Mike
    (That was 13,500 miles on each of his first two Kendas...)
    "A little hx, I just put Kendas on the front. I ran 13,500 on first Kenda & 13,500 on second Kenda. "
    No doubt; you've had GREAT luck with them!
    You might as well "Stick with the girl that you brought to the Dance!"
    Nov 2012
    hmmmm, bronze tire, cool idea but I would hang it above my tool bench VS sending to Kenda
    thanx Bob for clarification, 13,500ish per tire & metaphor to stick with Kenda
    Very Active Member coz's Avatar
    May 2011
    cincinnati, ohio
    Default Kenda rear tire
    I got 16-5 out of my original rear tire. I had a Kuhmo put on to replace it. Not only was it half the price of the kenda, it will last way longer.
    it was fun while it lasted.
    Default Like them....
    I got 22,000 miles on the rear and have 28,000 miles on the fronts. Replaced the rear with another Kenda and after 6,000 miles its looking good. I will be changing the fronts soon and have new kendas on hand...glad I'm not alone..was starting to worry...
    Nov 2012
    Coz,
    Do you notice a difference between Kenda & Kuhmo on wet road?
    Chupaca,
    Yip, same numbers as you & Coz. How does your Kenda work on wet roads?
    Vermont
    Default Rear tire replacement
    My original rear tire (Kenda) I got 5,824 miles, and I replaced the rear tire with a General Altimax RT 43, last month. I own a 2014RTS-SE6, look @ the thread" Kumho Ecsta AST 225/50 R15 vs Yokohama S Drive 205/ 50 R15" and read my post # 6,+ 18( has pictures of my new rear tire). I do not feel a ride difference with my new Tire. I have not ridden in the rain yet. Deanna
    Gremlin Bell
    SpyderPops Missing Guard Belt
    Ultimate F3 Floorboards
    Sway Bar with Links
    Rolo Laser Alignment
    Half Cover
    Show chrome Trunk Shock
    Default Gotta say..!!
    Coz,
    Chupaca,
    I have not seen anyone complain about the performance of the tire in any condition. The issue with durability is the main complaint well and cost. I buy on ebay and save big time...I love the way it handles on wet roads and dry roads and have had to deal with hail and snow as well. But apparently its only me hanging in there with kenda..
    Nov 2012
    lol, 2 of us hanging with Kenda..........I might need/utilize a different tire if I'm pulling a trailer, hauling a passenger, using saddle bags, carrying tons of supplies, carrying groceries, & having extra weight from heavier models.
    Very Active Member PistonBlown's Avatar
    Jan 2013
    Christchurch, New Zealand
    I think it was your suggestion Chupaca that local road surfaces play a large part in how the rear Kenda's wear and to me that makes sense.
    I only got around 9000km (5500 miles) out of Kenda's on the rear (though I replace them just before the minimum tread markers). The road surfaces here are chip and tar and pretty rough.
    Switched over to Toyo T1R and wear is no longer an issue.
    I have found that the handling in corners has altered since changing to a Toyo. It's hard to explain but there's no lateral movement at the rear like you get with the Kenda's. It's more precise but also a little bit more jittery on unevenly surfaced corners now. I suspect this is because it has less flex in the sidewall.
    On cold days with the Kenda it would often loose traction on tighter turns e.g. pulling out of a junction. Not had this once with the Toyo.
    At the front I've kept the Kenda's as they seem to be fine.
    Oct 2013
    rome new york
    I have over 9000 miles on my kendas and still good tread left on all 3
    May 2011
    cincinnati, ohio
    Default No rain yet
    Haven't been caught in the rain yet with the Kuhmo. That might be 'cause I try not to. I don't ride in the rain on purpose. It did rain on me a couple times with the kenda, and it did just fine.
    Oct 2011
    Kalamazoo, Mi
    Wow you all are getting great mileage out of rear tires.I have 7300 miles on mine and feel that I don't want to drive the 700+ miles to Spyderquest on this tire. Have new Estka (sp) ordered from discount tire, will change it soon.
    2018 F3-T
    2018 F3-T , Pearl White
    Default TOYO T 1 R
    Quote Originally Posted by PistonBlown View Post
    It's you me with this tire, I have the 185/55-15's on the front, and they STICK LIKE GLUE.......What size did you get for the rear ?????...Mike
    Nov 2012
    PistonBlown,
    Cool how you are aware & pay attention to detailed performance of your rear tires & pros/cons of tire brands & aware of performance differences with temp differences. I'm limited in awareness; I'm aware of hydroplaning, spinning at track, & balding tires way past minimum tread marker. Toyo T12 looks interesting & Mike says stick like glue, gotta check out this brand.
    Nov 2012
    Deanna777,
    Thanx for the details & link to previous posts.
    Nov 2012
    Quote Originally Posted by IGETAROUND View Post
    Hi IGETAROUND,
    What tire is this "new Estka (sp)" I did a web search & couldn't find it.
    Mar 2015
    NE Kansas
    I think the reference is to a Kumho Ecsta.
    Dec 2014
    California
    Default rear tire
    I too have a r standard shift 2014--- What size rear tire did you buy ? And how much was it -out the door ? I just went with the standard tire from the dealership ( Can't remember what brand ) but the first one went 5200 miles and was not quite bald. I now see the Spyder's are kind of pricey for everything. Don't know if I would buy another one. But at my age (72 ) -How much longer am I going to ride ? That's why I went with a trike.
    May 2011
    Charleston,SC
    When I had my '11RS I got 27k on rear OEM tire and traded the RS with OEM Front tires at 30k.
    Jan 2013
    PistonBlown,
    Ahhh that's because I'm a creature of habit when I nip out to get lunch from work. The nearby town with 3 food places is about 10km so always doing the same route in all weathers - I know how the Spyder feels through every bend and junction come rain/sun/cold/hot. This means when something changes I notice it:-)
    The tire guy I used last time was really good, he had 3 or 4 suitable tires he'd used on Spyders before and asked me questions on how I rode, favourite routes, if I rode all year etc. From that he recommended the Toyo and I've been very happy with it. Funny enough wear wasn't a prime consideration though I wanted to last longer than the Kenda:-)
