I can't wait to see what you come up with!
Good Luck!
Look forward to see what you come up with. Does indeed need a solution and BRP is not solving it.
at SpyderFest a friend's saddleback latch broke in the same place... its obvious that BRP's quality is lacking...
osm
Originally Posted by Doc Humphreys
What I am going to do is make a repair/strengthening kit that will use a much larger area to secure it.
It will work for both broken and unbroken units and is a very easy install. I wish I had made and installed this before I broke that spot, but this will be a good repair and will be stronger than original. This will be fabricated for the the RT, but might work for other models. I will keep you updated!
Thanks. Let us know how and where to purchase when you're up and running with it.
RT and Gold Wing States & Provinces
I had the same thing happen to my 13 RTS. BRP replaced it under warranty.
2013 RTS SE5
2013 Kawasaki Vulcan Nomad 1700
Nice idea!
Considering all the reports I have seen recently of the hinge breaking, why not fix the problem before it breaks thus saving time at the dealer?
Bob
2011 RT-S SM5 - Black
I guess the problem, is that it takes a pretty fair amount of unhappy customers; before BRP will notice that there is a problem...
REALLY
I was bit by the dreaded broken hinge on the side case about a week ago. I finally had time to take it apart and found where it was broken. I was not impressed with the bracing that BRP had done and if I didn't know better, it is almost like that area was left weak on purpose. The bottom portion has a very narrow section in the front and back of that hinge area that can be easily broken. Usually, this would require the inner portion of the side case to be replaced and big $$$.
Doc, this is a picture of ....what ?.....the case ? the hinge ?.......Thanks .....Mike
WOW I DIDN'T KNOW THIS
Actually; BRP has been covering the windshield strut under warranty; even when the bike has had it's warranty expire...
They're aware of it, and MIGHT even be working on it right now!
But if they are covering it under warranty even if the warranty has expired ....then why did you buy an Aluminum one from Australia ????.....And there are a lot of folks here who aren't aware of this extended warranty and have been paying upwards of $ 700 to have it fixed...........Why is this news a secret ?????....................Mike
"covering it under warranty", just means that you get a replacement part of "like kind and quality"...
I chose to pay for an improved part.
Maybe...if the part that failed has been superseded, then if your timing is good, you might get an improved part.
In regards to what the Doc has devised, I too am unsure of his exact area where the repair is being accomplished. I have seen other failures posted here of a similar description. Enough that I personally had a look at how the hinge area is fabricated.
Like Bob, I too have the windshield arm in hand. It arrived yesterday. It is on the list of item to replace soon. The reason I decided to not wait for warranty is that most likely failure will happen during a ride and second would be I do not want anything to lessen the enjoyment or create fear for my wife on the back. It's money well spent towards what I would consider a safety item. If BRP does recall the windscreen support arms, then I will undo the work and comply.
As for what the Doc designed, yes, the failures are being replaced under warranty. Seems he has a solution for broken items or to simply reinforce non broken items. Seems if you simply ride local, warranty may be the most cost effective, provided the dealer is nearby and competent. If you travel, why let a stupid failure that may be prevented inexpensively ruin the trip.
PK
PK
Amen to that! "Prevention is better than cure" ~ Desiderius Erasmus, Dutch Theologian, 1466 - 1536
"Topper" is my Pearl White 2013 RT-LTD
Professional Retiree - liked it so much when I retired from the USAF, that I started another career so I could do it again!
Happy to be a member of the Maryland Spyder Web - find us at
http://www.meetup.com/MarylandSpyderWeb/
...And if the busted parts are being replaced with identical parts?
That's BRPs option. With that though, they can replace until warranty expires. Major PITA for the owner. In cases like that, they hedge the bet that few will fail and even fewer will fail a second time. The warranty time paid out simply comes from a pool of all machines purchased. Our 14's profits likely paid for a portion of the design, fabrication and install of the 2013 heat reduction recall. Just as the 16,17 and thereafter will be paying for the recalls and warranty work, if any, on the 14s. seems kind of like Social Security...
When I ordered the windscreen arm, the wife asked, why do we have an extended warranty? Two answers...She wanted one when we bought the bike and second was in case the engine fails or something super expensive fails. So, hypothetically, if the new windscreen arm is installed and used a while then the windscreen motor fails, I'll need to remove the upgrade arm and reinstall the original for warranty. Then go back and reinstall the upgrade arm, unless BRP has done that. Crazy but there is a method to the madness.
PK
In this case probably, but for medically sick people with Diabetes or Cancer, that statement is seriously flawed.
PK
ISSUES
PK
...Paul two things ...The NEW and Improved windshield part was a " BOLT " not the ARM that is the real problem !!!!!!.....and when you get around to putting on the ARM ( from the Aussie's ) take off the Magnet end ( after marking it's original location on the shaft )....I have taken off both the GEAR and MAGNET pieces......and the Magnet is far easier and less likely to break.......Mike
PK
The repair/strengthener we are making can be easily removed to have the warranty case replaced and no one is the wiser that it was even there. Only thing you will have to do is remove the unit and put the original screws back in. When I have a little time I will take some close-ups of the area and give you my take on it. They could have been made stronger than they were. Referring to the above picture, the voids on each side (yellow) recess back and form a stop on each side to hold the metal plate in position. This puts the portion on the bottom as the very small load bearing area, especially if you press down on the cover with it open. Even though the other case is fine I will do both for insurance. The kit will ship to repair all four hinges on both side cases.
Lydia-- "A stich in time saves nine"
Jack
2015 BMW R1200R LC
2014 RTL SE6 Pearl White
2012 RT-622 trailer viper red
2011 Polaris Ranger green
2016 Can Am Maverick
Testers needed
OK, I have finalized the kit today. It will require an inner and an outer bracket to work correctly. The bad thing is that the case is not formed the same for the front and back hinge. I fabbed up an outer bracket today and installed it and mine works as good or better than before it broke. Going to try to keep the costs down as much as possible.
Thinking about a couple of product testers. We will ship free to you and you give a write-up on how it worked, ease of install, etc. I need someone that has a 2014 RTS and a 2015 RTS for testers.
