F3 seat removal
Any ideas how I get the front and rear seats off the F3?
Ant
Yes . . . .
. . . . it is in the manual. The passenger's seat is released from/by the ignition switch- then you will see the two bolts securing the drivers portion.
Tom
2008 GS SE5 -> 2013 STS SE5 -> 2015 F3-S SE6 . . . Still riding & smiling.
SpyderLovers Founder
Pop the rear seat off using the key and then there are two hex head bolts (10mm) you have to take loose.
AHAH! easy when you how I guess?
Thanks
Ant
Rear seat in place (never removed) doesn't seem like it's attached well on one side.
From the back, left side lifts up with only a little pressure with one finger. (Appears to be only locked in place on the right side.)
Thinking something must not be right.
