Grip Puppies
I have a new to me 2012 RT and stumbled across Grip Puppies. Anyone use them? Do they help? Work with the heated grips? Easy to slide on? My hands tend to get numb when I ride, even when I have a very loose grip, so wondering if these are worth getting?
thanks for any light you can shed on them!
NOT FAMILIAR WITH THE TERM "GRIP PUPPIES", I RESEARCHED AND LOOKED FOR LARGER GRIPS, SEVERAL M/C DEALERS, THEN WENT TO THE CAM-AM DEALER. FOUND THAT NO ONE INCLUDING BRP MAKES A LARGER GRIP. HOWEVER THEY HAD A GRIP COVER THAT (LOOKS LIKE A SOCK) SLIPS OVER THE PRESENT HEATED GRIP. IT WORKS GOOD NOT QUIT AS LARGE AS I REALY WANTED. I HAD THEM INSTALL, IT CAN BE TRICKY DUE TO THE RETURN SPRING ON THE RIGHT HANDLE BAR, IT WORKS AND THE HEAT WILL ALSO WORKS I THINK THE PRICE WAS AROUND $13.00
LARGER HANDLE BAR GRIPS
TricLed has some foam grip covers that work great, they slide on over your original grips and absorb most of the vibration and are real comfortable, they look great, they work well with heated grips also. Grip Puppies are hard, have an annoying seam and don't last very long. MY .02 cents worth.
Cruzr Joe
I have a pair.
They're fine. Very easy install and no problem with heated grips.
So far, my second childhood is better than my first.
Get the ones from Tricled.
4" Stubby antenna, Dual arm LEDs Fender LEDs, Back Rest, Luggage Rack, Run, Brake and Strobe for top case, Mirror LEDs,Back Off decal on mud flap, reciptal for Battery Tender and Heated Gear, mirror LEDs that stay on or work with blinkers, GPS, side bag red LEDs, Top cuff with Ram Ball phone holder And USB power, Top cuff with drink holder and passenger cup holder. Also grilles in front of radiators, also spyclops. Garmin 595 GPS, Freedom windshield. Also glove box console And trunk wrap in carbon fiber from wrap my spyder. BRP comfort seat. added garage opener with rocker switch in center console to match other switches. And I have added Elka stage 2 shocks.
Grip puppies are cheap, easy to instal, increase the diameter of the grip nicely and allegedly work well with heated grips. Can't speak to that, use heated gloves. And if you decide you don't like them they remove as easy as they install
All the great movements in the world began with a cup of coffee!
2018 F3-T
My mods: Can am Trailer hitch, USB and 12 volt power outlets, Gustason windshield, Bead rider seat cushion, battery harness for electric gear and battery tender, Time out trailer.
Agree..!!
you can also try the weighted bar ends to help with vibrations. I also use heated gloves and prefer to have the grips to where I can wrap my hand around them. They are inexpensive they do work and you can get them on and off easily...
2012 RS sm5
I bought a pair of "slip over grips" at SpyderFest -- $14... they work ok for hands, BUT I CANNOT FEEL ANY HEAT THRU THEM.. they look like the same material that is used for pipe insulation.. come winter time.. I will have to remove them...
osm
I use them, and really like them.
You'll have to trim the right side a little, so it doesn't go over the grip to the bar end (it will bind the throttle if you don't)
The heated grips work very well thru them.
To install them, I take a tall water glass mostly full of water, with a little bit of dish soap. Soak them in there for a few seconds, and then work them on the grip.
If you have an air compressor, it'll go a little easier, as you can just use the air nozzle to push air into the open end of the grip puppy, to help lift it up and slide it on. It's optional, but makes it a little bit easier.
I really like that they expand the diameter of the grips, so my hands are more comfortable.
-Fratz
The original Grip Puppies were sold by an enterprising vendor on here for awhile. They are no longer on the site.
We bought a pair for each . I liked them for the feel, (making the handgrip "fatter"), and helping to cut down on vibration.
I felt that heat transference for cold weather riding was not good on my machine (2010). Akspyderlady did not notice any problem with heat transfer on her 2011.
I do not use mine any more, and she still has one on her throttle grip.
GRIP COVERS
These covers are made from EDPM which I believe is very similar to NOEPRENE....( skin diver suits )....Bike Bandit sells them and also DENNISKIRK.COM part # 595294 $ 12.95....( these are the larger diameter so should fit better ) according to reviews the heaters will work.....They should also last much longer than open cell foam ( ie. grip puppies ).....Mike
Grip Puppies
Love mine and wish I had put them on first thing instad of waiting , would not ride without them , hands no longer go to sleep or crampup.
Tricled Grips
I'm in Cruzr Joe's and samwok's camp. The Tricled grips work very well with my heated grips.
otherwise be a vulgar brawl.
Cognac 2014 RT-S
I use them and am pretty happy with them. I had them on my previous bike too. They slide on nicely with a bit of hair spray inside first, and yes, the heated grips work just fine thru them. Cut to length with a pair of scissors first.
I have tried them. Like the Grip Buddies much better.
Personally, I use Grip Buddies!
AJ
2014 RT-S
Akrapovic Exhaust & Cat Bypass
Bajaron Sway Bar w/links / Sena SM-10/Garmin 660
Comfort Seat w Adjustable Backrest
Decals by Purple Harley / Magic Strobe
Kuryakyn Black Widow Pegs Rivco Highway Brackets
Rivco Trunk Mounted Double Flag Holder
FOBO / Spyder Cuff / XM Radio w MC Antenna
Grip Puppies I have used them on all my bikes since they first came on the market. I have had carpal tunnel in both hands. They just work and heat well too
2013 Mag Silver SE5 RT BahaRon Sway bar & Sway bar links, Grip Puppies, Kuryakyn Helmet locks , Ultimate Seat w/Utopia Backrest, Dash power outlet, Spyderpops BumpSkid, Swagman Cup holders, Full size Brake Pedal, Seal DLX Floorboards, Freeway Blaster horns, Sylvania Super Bright fender LEDs, Scotchlite 680 Rear & Fender Reflectors, BRP Fog Light Kit, LED Mirror turn signal strips, 2014 RT grille mod. Outlaw Laser Alignment
Another Option
And here is yet another option. These are similar to Grip Puppies (which I have used and like) but they are a wrap with a hook and loop closure making them easy on and off and even temporary if you like. Yes, they leave a "seam" that you can feel on the grips because they are removable but you can get used to that and you can position the seam closure in any area where it bothers you the least.
Neoprene foam grip wraps
http://www.ascycles.com/detail.aspx?ID=43208
http://www.nojgear.com/NOJ_Neoprene_..._p/gw01-01.htm
The second link I believe is direct to the manufacturer. I do use these on my own Spyder RT-S but being in Southern California in the summer with a bike that is only 1 month old, I haven't had a chance to check them with the heating yet. Of course, if I don't feel enough heat, all I need to do is take them off while it's cold and then put them back on the next day.
2015 RT-S SE6 Red Pearl - aka "Ruby"
Tri-Axis handlebars - Bajaron Sway Bar and Heim Links - Roadster Renovations Spring Stiffeners & Top Case mirror - Value Accessories 3 pc. Lid Net Set - Lidlox Helmet Holders - JT's Dash Mount Bar - Drink2go rider & passenger cupholder - Wolo Bad Boy Horn - Show Chrome Trunk Rack - 12V power & heated gear ports - Spyderpops missing belt guard - BRP Trailer Hitch - Gold Plug hex head drain plugs
NOPE
I dis-agree they aren't like " GRIP PUPPIES " ....puppies are made from OPEN cell foam.......The above are NEOPRENE and are CLOSED cell foam.........They are very different................IMHO the neoprene will outlast the puppies X 3.........Mike
Pragmatic Member
Cruzr Joe
Thanks for the lead Joe. I ordered mine today!
Pam
- 2015 RT-S Special Series / Red & Black
- Baja Ron Sway Bar
- Utopia Backrest
- F4 Customs tall and wide vented windshield
- Stebel Super Loud Air Horn
- Baker Built Air Wings
- LaMonster Highway Pegs
- SpyderPops Exhaust Block Off Plate
- SpyderPops KOTT Grill
- SpyderPops Belt Guard
- Cat Bypass
- Laser Alignment by Squared Away
- TricLED Fender Lights
- General Altimax RT43 rear tire
- Dual flag holder
- Mud Flap
- A$$hole seeking missile system
