BRP got it right!!
I got my bike back from having the recall done last week and I finally got a chance to ride it today. WOW what a difference!! I never had an extreme issue with the heat, but there was def some heat. Now after the recall...here are my observations... the heat is gone! the glove box is actually cool to the touch inside. I have Corbin seat with the fuel door and the heat used to pour out of that door... Now it is cool. The bike has a little more mid-range power and, for some reason, it seems to shift smoother...although that makes no sense. I loved this bike from the day I first got on it... NOW I am even more in love with it!! Well done BRP
Jonny
Jonny
2013 Spyder RT Limited
- TricLED 3rd and 4th Brake Light
- Spyderpops Bumpskid with TricLED LED kit
- GloRyder Wheel Lights
- Spyderpops Missing Belt Guard
- Corbin Arm Rests
- TricLED Turn Signals
Same experience I had . . . there was an update to the nanny computer . . . that could account for the smoother shifting
"Topper" is my Pearl White 2013 RT-LTD
Professional Retiree - liked it so much when I retired from the USAF, that I started another career so I could do it again!
Happy to be a member of the Maryland Spyder Web - find us at
http://www.meetup.com/MarylandSpyderWeb/
Great news..!!
glad to hear that even those without the great heat issue can see such a difference. thanks for posting....
2012 RS sm5
2014 grill cut to fit will fix that
2013 Mag Silver SE5 RT BahaRon Sway bar & Sway bar links, Grip Puppies, Kuryakyn Helmet locks , Ultimate Seat w/Utopia Backrest, Dash power outlet, Spyderpops BumpSkid, Swagman Cup holders, Full size Brake Pedal, Seal DLX Floorboards, Freeway Blaster horns, Sylvania Super Bright fender LEDs, Scotchlite 680 Rear & Fender Reflectors, BRP Fog Light Kit, LED Mirror turn signal strips, 2014 RT grille mod. Outlaw Laser Alignment
Yes, I've considered installing the 2014 grill, and I've considered cutting holes in the under plates and skid-guard plastic so that I can put a metal sheet behind that 2014 grill and completely block the air flow. But I think that directing more hot air under the bike will exacerbate the problem of heat coming out from under the bike and onto the footrests (mine and the passenger's). I believe there should be a sufficient exit point somewhere behind the passenger footrest to draw the heat out from under the bike and direct it away. As it is now, heat bottlenecks at the middle of the bike and cooks the riders. There's still a heat trap under the tupperware.
I'm considering adding heat reflecting, self-adhesive material to the back of all the body panels. I'm also going to investigate putting a thermostatically controlled fan that points downward and will force heat out of the heat trap. There may be room where the battery used to be (under the seat in earlier models). If that doesn't work, I may create a v-shaped vent into the rear wheel well. I've got to get that excess heat out and direct it towards the rear of the bike so that the air flow will work to my advantage.
Heat wrap exhaust headers, remove the cat converter and install bypass. This will greatly reduce heat coming from underneath. 2014 grill will reduce right foot heat. Bike will also run much better.
Has anyone had a similar experience? Does anyone have a solution for directing the heat somewhere other than at the floorboards and rear footrests on the RT-S?
My solution:
http://www.spyderlovers.com/forums/s...ght=heat+block
Plus see post 21 here:
http://www.spyderlovers.com/forums/s...TL-POST-RECALL
2014 Copper RTS
You do not need to modify the 2014 part to fit. The tab on the right that you removed is fastened with one of the plastic pop rivet fasteners. It fits as designed if assembled in the correct order.
We also mostly blocked the upper grille area with black mesh cloth. All the heat goes out the bottom now. Much better.
I modified it for easy install or removal and to allow the bottom to be a flap door
