Alarm system for 2013 RT
Does anyone have any recommendation for the RT? The service technician says they really aren't recommended because of the nanny and the ignition system?
Originally Posted by akspyderman
Another good question. Should I, or Shouldn't I.
My take: Alarm systems are a bit expensive. The is programmed to not start without the coded key present. That should provide enough deterrent for most. Some people cannot even start them with the key--as in, failure to press the mode button after boot up.
A determined thief is going to take your --regardless.
Adequate full coverage insurance to cover you in the event of a theft is where I am at.
Sorry, but I do not have any recommendations for alarm systems--which was actually your question.
Thank you
I have a Scorpio i900. I had one on my 2010 RT for four years and I have had one on my 2014 for a year and a half. No Problems. I only use the perimeter and vibration sensors. I did not connect it to the ignition. I use it to keep from people messing with it or sitting on it.
2014 Timeless Black RTS/SE - BRP CB/Comm System; BRP Zumo 660 GPS System; BRP Cellphone Interface; BRP ST-1 Helmets w/BRP Headsets; BRP XM Radio; BRP Tri-Axis Handlebars; BRP Adj Wind Deflectors; BRP Adj Vent Windshield; BRP Comfort Seat & Utopia Backrest; Corbin Armrests; HMT Brake Light; TricLED 3/4 Brake & Running Lights; TricLED Fender Lights & Rr Cargo Lights; CD Fender TIPS Kit; Bump Skid; Scorpio i900 Alarm; Touratech GPS Locking Mount; NBV Highway Mounts; BBP Brake Pedal, Stebel horn.
Yes tampering and vandalism is what was mentioned to me. ..thank you I will look into it.
SPY 5000 alarm system. Uses vibration and a microwave sensor which I set so that anyone in the Y would cause it to chirp.
Mainly use it to keep idiots from getting on the Spyder when your not around. Believe it or not had it happen twice but not anymore.
http://www.spyderlovers.com/forums/s...-and-How-Too-s
Bob
2011 RT-S SM5 - Black
It's a choice...
depends on where you are, travel or stay...as far as theft I agree with AKSpyderman. But for a deturrent for the curious and photo op folks it works well. I use a pull over heat and rain cover to do that. There are systems out there but the installation can be tricky...
Gene and Ilana De Laney
Mt. Helix, California
2012 RS sm5
