Jack
Looking to install Sway bar, normal floor jack work? Where's a good jacking point?
2014 Black RTS SE6
2012 Black RS - Sold 7/24/2014
2011 Sonata LTD
PETE
Normal will work OK, you must be careful of tipping it.......ONLY PLACE JACK ( OR PETE ) UNDER THE FRAME........Mike
If you don't have them already pick up some rhino ramps. They work better and are a ton safer too.
Sent from my SCH-I545 using Tapatalk
I believe that with the RT you need to get it higher, 24" or so. Do a search there is at least one video.
One of the hardest decisions you'll ever face in life is choosing whether to walk away or try harder.
Ramps
Unless you are an extremely large person, two car ramps will work fine. They are very stable too.
2011 RTS (Sold to a very nice lady)
1998 Honda Valkyrie
2006 Mustang GT. Varooooom!
US Navy Veteran
SC Law Enforcement Boat Captain
CNC Machine Service Technician
President: Rolling Thunder SC1
Member: Disabled American Veterans, Rock Hill, SC
Member: American Legion
Experience is recognizing the same mistake every time you make it!
Have you installed Ron's bar on your machine with standard car ramps?
2014 Black RTS SE6
2011 Sonata LTD
Originally Posted by Chupaca
on how high. Ron's instructions are great..
these with jack stands work well. One fellow here put ramps on his tailgate and ran the spyder up enough to do the work..[emoji106]
What type of jack is the one you are using? I'll like to get one.
Sent from my SM-N910P using Tapatalk
This one is from sears but harbor freight has them in blue. ATV/motorcycle lifts ...
2012 RS sm5
22 inches
I just put on my swaybar this weekend. You NEED 22 inches minimum to swing the swaybar out. The jacking up was the hardest part, the installation was smooth!
when I installed my sway bar... I loosened all the bolts using a pair of ramps under the front wheels... then I used 2 - 2x12's placed on the back of my truck.. once on the 2x12's have someone block the rear wheel.. the parking brake is not strong enough to stop your spyder from backing down... then take out the old sway bar & put the new one in... back your spyder down & finish the install..
osm
