Results 1 to 15 of 15
    Apr 2015
    Green Bay, WI
    Default SE 6 shift delay time
    I have a 2015 F3's with thumb shift auto. Is it normal for approx 200+ ms between shifts? I have a Suzuki Hayabusa--actually I've had 3 of them. Using air shift solenoid is set at 50 millisec. I know the F3 is electric shift but it is a very long delay between engine cut off & upshift engagement. Is there anyway to reduce this shift time delay?
    Thank you kindly,
    Darrell
    Active Member can-am sam's Avatar
    Jun 2010
    Ferndale, Washington
    When up shifting are you holding the throttle steady, not letting off of it. If you let off the throttle when upshifting it can make for longer shifts. This tends to confuse the computer.
    Apr 2015
    Green Bay, WI
    Quote Originally Posted by can-am sam View Post
    Full throttle appears to be the longest delay. If it was a manual--I could shift in less than 50% of the auto shift delay time. When I back off throttle during shift at least its a non-jerking shift. I'm happy I bought the high back passenger back rest or else I might lose my wife on full pwer shifts
    Default INTERESTING
    Quote Originally Posted by Wildrice View Post
    My 2014 RT has essentially the same engine and trans.....When I drag raced it at Spyderfest I did full Throttle shifting ( SE-6 ) and did not notice any delay or jerk in my trans.......Perhaps mine is more broken in than yours.........Mike
    Jul 2015
    Canada
    My F3-S SE6 also has a long delay when shifting. Has Wildrice resolved his shifting delay?
    Did you check to make sure that the oil level in the engine is correct?
    One of the ways that these bikes will tell you that they "need a drink", is by having the shifting start to get a bit on the wonky side...
    Jax Beach, Fl.
    I only get the delay up shifting from 1st to 2nd & 2nd to 3rd. I've learned to just get use to it.
    2014 RTL-SE6 Cognac (Current Love)
    2012 RTS-SE5 Pure Magnesium Metallic (Pre Loved)
    Active Member TommyBwell's Avatar
    Jun 2014
    Atlanta, GA
    My first automated manual transmission was a BMW M3 with DCT. That really spoils you. I have been through a number of vehicles without DCT and have always been disappointed with the amount of time it takes to shift. Until I got my F3 that is. I'm too old to register ms but I am happy as I can be with it. Unlike the DCT I do not believe it is faster than the manual but unlike others I do not believe it is slower either.
    2010 RTS-SE, Orbital Blue
    Sep 2009
    illinois
    With my semi automatic I don't ever miss a shift, or grind a gear.
    Very Active Member garb55's Avatar
    Coolidge Arizona
    Quote Originally Posted by retired1 View Post
    And you are always in 1st gear when you take off from stop
    Now 2014 RT Limited Cognac
    Was 2008 GS SM5
    Don Garbarino
    Cup Holder
    GPS locking holder
    Mud flap
    Modified KNOTT grill
    Phone holder and charger
    Trailer hitch
    Dual air horn
    Auxiliary fuse box with relays
    Heated clothing controller
    volt/oil pressure gauge
    Sequential signals in mirror
    Tri Axis Handle bars
    Baja Ron anti sway bar/heim links
    shorty antenna
    And many more
    Registered Users Tweakers's Avatar
    Nov 2015
    Florida is home, working in Oregon
    The SE always disengage the clutch between shifts. On my old sports bike I never used the clutch to shift, resulting in incredibly fast shifts.
    Jack & Carol Jo Stewart
    2015 Spyder RT-S SPECIAL
    TBR Slip On Exhaust
    Corbin Heated Lemonster seat with back rest
    Semi Hard Luggage
    BahaRon Swaybar
    JT's Dash Mount
    TricLED Front Fenders
    XenonDepot LED Headlights
    More to follow! Lol
    Active Member Samir221's Avatar
    Jun 2014
    Deltona, fl
    I noticed the same problem with my f3 as well as my old 13 Sts.
    the problem was solved with my Sts when I took it for the 3000 miles service and that is why I am not worried about the f3 acting the same way. Not sure how many miles u have on ur f3 but I believe once the engine is broken in properly and initial service is performed the lag would be unnoticeable
    If you're counting the number of milliseconds between shifts; you are REALLY missing out on the important stuff...
    Apr 2015
    Green Bay, WI
    Default shift delay cured itself after approx 800-1000 miles
    Quote Originally Posted by OttF3S View Post
    F3's runs much better now with 1400 miles on it--I'm a short haul driver--longest ride was approx. 100 miles. I drove a few cars & motorhomes coast to coast a few times--just not interested in long rides anymore---fast rides are handled by my 2007 stage 2 turbo Hayabusa...It's a spiritual experience. Wife loves the F3's over any other 2 wheel bikes I've owned--so do I. Slow speed--3-5 mph parking lot maneuvers have taxed m balance co-ordination--especially with a rider sitting higher with more balance leverage. Besides some vibration issues---larger saddlebags would be great--but paying $1300 the 1st time slows my change out process. It looks like the 2016's F3 touring saddlebags have increased volume---it's always something.. 35 degree temp in central Ohio & my SUV with heated seats won today:-)
    Darrell
    Apr 2015
    Green Bay, WI
    Default Ya gotta be fast to count milliseconds
    You've had your hair done-huh Bob? ---nice color --but it gives you that long face look.
    Darrell
Tags for this Thread
