Results 1 to 14 of 14
    Jun 2015
    Midland, TX
    Default Pitbull Motorcycle Jack
    Anyone using a Pitbull motorcycle Jack to lift your RT? I have the air over hydraulic standard lift. According to Pitbull, I need the Dyna lift because the standard size jack will make contact with the exhaust.
    Any pictures of the lift under the trike is appreciated.
    Default Here you go..!!
    though this is an RS same lift is used on RT's...
    Mar 2012
    Beaverton, Oregon
    I have a full size Handy lift but also often use a J&S Jack.
    2015 RT Ltd , Canamspyderaccessories Brake pedal ext. Red
    Apr 2014
    Indiana
    Default Pittbull Jack
    I use a Pitbull jack to lift my 2014 RT with no problem. I did put a piece of 1/2" board (4" Sq +/-) on the on lift bar side toward the rear wheel on the frame and the front went across the main frame and the bars that run to the outside from the main frame. I did not take a picture but with me that is part of the course.
    Sep 2014
    3rd ROCK FROM THE SUN !
    I have this 1700lb motorcycle jack from Amazon.. it works perfect for my 2014 RT spyder.
    May 2013
    Stanton, ca
    Using the Harbor Freight ATV jack. Been using it since day one. Works fine on my RT.
    http://www.harborfreight.com/1500-lb...ift-60536.html
    Bob
    Jun 2015
    Midland, TX
    My Pitbull air over hydraulic jack works fine with the Spyder.
    Sep 2014
    USA
    just dont take off one of the front wheels the bike will tip other than that those jacks work great??
    RT-S PE#0031
    Jun 2009
    Snellville, GA USA
    The Pitbull lift has tie down points to secure your bike or Spyder. If used, it shouldn't be a problem.
    I have the foot pump style Pitbull, which I bought many years ago. Love it. I now also have a table lift (air), which does a great job too. Had to add 9" width to the 48" standard width to accommodate the wider front wheels of the Spyder. now I have to back the Spyders onto it, but I can do that! It was originally designed for standard trikes.
    USA, Alabama, Leeds
    Quote Originally Posted by KJWEB View Post
    Model #, cost please
    TIA
    Nov 2013
    Oro Valley Arizona
    ​Those same Jacks are yellow at Sears and blue at Harbor freight. Pit Bull does not manufacture them. They do use them. Just to clarify for the Newbies.
    Jack
    Even old "square Joe" uses one.
    2015 BMW R1200R LC
    2014 RTL SE6 Pearl White
    2012 RT-622 trailer viper red
    2011 Polaris Ranger green
    2016 Can Am Maverick
    USA, Alabama, Leeds
    Thanks Joe.
    Apr 2013
    Atkins, Arkansas
    Regardless of what you use o jack up the Spyder, USE floor stands before working on your Spyder.
    Jul 2015
    Danville, KY
    Quote Originally Posted by ursamajor35126 View Post
    TIA
    http://stores.pitbullbikershop.com/
