cat bypass springs....
Installed my cat bypass and yes the top spring is as difficult as everyone says it is. But after looking at it, wondering why a clamp wouldn't work. Anyone try one? Thinking I may investigate.....
Current: "Scarlett", 2017 Can Am F3-T, SE6, Intense Red Pearl.
BRP heated grips, DIY brake light strip and turn signal strips, Chrome/LED brake light tag frame, SpyderPops bumpskid, Baja Ron swaybar and billet links, Lamonster Third Peg, BRP Adjustable Passenger Backrest, SpyderPops Missing Belt Guard, ShowChrome oversize brake pedal, TricLED foglights.
Previous: "Synthia", 2014 Can Am Spyder RT, SM6, Pearl White.
Yes the top one is a bitch.I figured a way to do it pretty quick and after its done its done.Probably never have to mess with it again
2014 RT-S SE6 Pearl White
Grip Puppies, 12 volt power outlet, BRP comfort seat, Tri-Axis adjustable handlebars, BajaRons sway bar & links, Spyderpops Bump Skid w/Inlaid LED's & Stainless steel Kott grilles,SmoothSpyder belt tensioner,Carbon fiber dipped wind deflectors,Lamonster NBV highway brackets,Lamonster cat delete pipe,
it's still hard even with the tool, someone on here had a good idea, they said to mount the one side of the spring, and use a string through the other side to stretch the spring to get it on
NO BIKE AT THIS TIME
Originally Posted by Dragonfly
I purchased a headlight spring tool. Well worth the $14.00 and have found other uses for it so it definitely has paid for itself.
have used the same tool to remove exhaust pipie springs on snowmobiles and also helped a friend install his cat bypass. right tool for the job
CUZ, also read that, tried it , did not work for me. Oh well.
SpyderLovers Sponsor
Wire coat hanger
Coat hanger. Stretch out, wrap around a screwdriver as a handle. Pull spring in place. Cut hanger away. Done. Free. Painless!
Joe Meyer
Unless the Missus figures out where the coathangers are disappearing to...
One of these comes with the Yoshimura R77 pipe. FYI.
