2010 Can Am Spyder RTS SM5 Code P0480
Does anyone have any experience with code P0480? I know it's a ground fault issue with a fan. Any help in getting me started with a resolution is appreciated.
There is a fuse F4 in the front fuse box, this supplies power to the relay R4 also in the same box in the cooling fan circuit.
Try those as a starting point.
2015 Intense Red Pearl RTS SE6 - Laser Alignment by Precisyon Trac, Tri-Axis handle bars, ? to be determined.
2014 XLR Viper 305V14 Toyhauler (Home)
2015 Ram 3500HD Crew Cab
Former Spyders
2010 Blue RT A&C SE5 53K plus miles - never left us stranded!
2013 Pure Magnesium Metallic ST SE5 11K plus miles - never left us stranded!
http://www.spyderhelp.com/Menu%20Pan...artMobile.aspx
FAULT CODE: P0480
MODULE: ECM (Engine Control Module)
DESCRIPTION: Radiator cooling fan relay
POSSIBLE CAUSE: Blown fuse Damaged or disconnected headlamp over run switch relay wires ECM
SERVICE ACTION: Check fuse.Disconnect relay.Measure resistance from harness connector: ECMB-J4 to FB-C8 (expected value: < 2 ohms) .
Thank you.
