Results 1 to 14 of 14
Thread: Which Truck?
    Active Member telespec's Avatar
    Nov 2012
    Houston, TX
    Default Which Truck?
    Am looking to get a new pickup truck that I could put my 2012 SE5 RTS into the bed of the truck, any suggestion?
    2012 RTS SE5
    SpyderPops BumpSkid Guard
    PowerSportsWraps Phoenix Bird
    GloRyder Lights for Front Wheels with Remote
    Lamonster IPS
    PowerSportsWraps RT Dash Kit Woodgrain
    Custom Dynamics Chrome License Plate Frame
    Shortee Antenna
    Knight Riderz Light Bar Blue
    Front and Back Spyder Decal
    Volt Meter
    Digital Clock
    Wolo Bad Boy Horn
    Lamonster LED Headlights and Fog Lights
    LED Tip Lights
    LED Light Strips for Front Fenders
    LED Light Strips for Left and Right Turn Signal
    Third Brake Light for Rear
    2012 RTS , Blue
    Very Active Member SNOOPY's Avatar
    Aug 2013
    Light truck beds are 4' between the wheel wells.
    Thats a standard to load a sheet of plywood.
    Spyders are 5' plus wide.
    Very Active Member M109Dreamer's Avatar
    Mar 2011
    Jackson, MS
    And if you load it backwards you'll nedd to remove the windshield or it could break.
    2007 M109R LE - To many MODS to list. Its cheaper that way!!!
    Default MY TRUCK
    Probably not your answer but,.....when my car died I bought a 2003 Toyt Tacoma. Took off the bed ( which I sold for $1200 ) and made a flatbed frame which I covered with plywood. I added air bags ( from AIR-LIFT $ 200 ) to compensate for the extra weight. Spyder rides facing forward so windshield is not an issue........Mike
    Very Active Member Lin's Avatar
    Apr 2013
    Somersworth, NH
    Default It's the bed size
    You could replace the standard bed of a truck with one from Aluma.
    http://www.alumaklm.com/truck-beds.html
    2016 RT-S Special Series
    2016 RT-S Special , 2 tone black
    Default Really..!!!
    This one merits a picture...
    ​2012 RS sm5
    Jul 2013
    Buck lake Alberta
    Default spyder in pick up
    Quote Originally Posted by telespec View Post
    as per attached photo,Ameri-lift hydraulic deck works.
    Jul 2013
    Buck lake Alberta
    Proper name is Ameri-Deck not Ameri-Lift.....Spyder is 62.5" wide, so this deck lifts over end gate opening and settles into box above wheel wells(trike still sits within box). Full size trucks( above wheel wells )are at least 64" wide.
    The trick to lifting your Spyder up to that height in a pickup?
    Having the pickup properly configured to safely handle the load...
    If it's got a Heavy-Duty package of some sort... (HD springs, axles, lower gearing, etc...), you should be okay...
    I have heard that Ford has a package that is pretty much designed for those campers that you stuff into the truck bed...
    Aug 2013
    Slide in campers, had one for years we used in our F150. Towed our ATVs in a trailer behind. Never an issue.
    Jun 2014
    People's Republic of NY
    K O O L
    please sir, may we see some pictures
    committee for postings
    Nov 2012
    Houston, TX
    I would like to thank everyone for their input and I will post my choice when I decide which truck.
    2012 RTS SE5
    Lamonster IPS
    Shortee Antenna
    Volt Meter
    Digital Clock
    Wolo Bad Boy Horn
    LED Tip Lights
    2012 RTS , Blue
    This could make buying a new Spyder look easy...
    Happy Hunting!
    Very Active Member ingramwc's Avatar
    Oct 2008
    Kingsport, TN
    Good luck! I would think that putting the Spyder on a trailer and towing it would be a whole lot easier and less expensive. Just my $.02!
    Current ride: 2013 Circuit Yellow ST-S SE5
