Waterproof USB cable
I had the usb port installed on my F3 and now I need to run cables from the seat to the front for gizmos. Are there any out there that are waterproof?
Suggestion for ya. I installed a standard 12V (BANDC) under the seat, and have another coming (BANDC USB DualPort)
on Saturday. I intend to use the spot to the left of the key and the 12V harness that is supposed to be
under that left-lateral panel for it. (Those "plugs" actually have harnesses terminating behind them
where left is for AuxLights and Right is Heated Grips... as someone answered to me the other day with
a different post).
You could just use that one which would be closer vs running a line from the seat forward... saving that
one for something else. (Just a thought)
Twist the ring around the key that has the markings on it, the ring comes off, the panel comes up and
you can see what's behind there. (It is a bayonet style release 1/4 turn...)
2015 F3-S SE6 (Rorange)w/BlueRidge windscreen, +2 UFIT, pass backrest, pass floorboard, CrossCountry Saddlebags, BajaRon sway w/links, BANDC 12v under seat, BANDC USB left of key plug, GripPups, x-Creen Sport, 2-Up Rear
2008->
Victory Vision Tour Premium
Ducati 900 SS Full-Fairing
BMW F650GS
Pre-1979
Suzuki GS1000-E (1st Tri-State Area)
Suzuki GS750
Suzuki RM125
Suzuki GT550 (3Cyl 2-stroke Street)
Honda CL175
Honda SL125
Honda Trail 70 (1st year of hand clutch model)
Honda Mini-Trail 50
Thanks, guys. I have the Can Am usb under the seat. It does have a lid, but its no good when I am using it. I just hope water does not get in there.
Originally Posted by CanAmChris
all these look to be extension cables. What I need two male ends, one the regular size and the other a mini.
