I made the bracket to raise the rear 2 inches. I also welded small tabs to upper part of bracket so it bolts up tight and doesn;t just pinch the rubber washer. Far more sturdy than original. The windshield extension is RS-S windshield that came that bike in 2011. I just polished the black paint off and mounted where I thought it would work best. I'm 5' 10 the improvement is amazing. I ride around here on freeway at 75mph or side roads at 55mph. It would be nice if it was a little wider at the top, but there is only slight buffeting without a helmet, and none with one. I was going to go with F4 customs, but right now this does everything I want and it didn't cost anything. I clamped the RS windshield to the Blueridge and used the existing holes to mount. I used SS button head bolts with SSwashers, and SS nylok nuts. Hope this helps.
Great - thank you for sharing!
2020 RT Ride Frequent Stay Safe
Aftermarket Aux Light, GPS mounting/wiring, Lamonster Garage Mirror Lock, Lamonster Garage Belt Tensioner
Backrest Home Brew Mod
2008 RS from 2008 through 4/2015, 2015 F3-S from 4/2015 through 9/2020
