Never seen that. I'm going to guess that when running your sucking up the coolant from the leaky reservoir into the intake tube???
Sent from my SCH-I545 using Tapatalk
Tim,
Last year I had gone to Lowe's, and when I returned to the Spyder, there was antifreeze on the ground.
Long story short, I changed out the coolant tank and all OK.
2009 GS SM5
I'm guessing thatt's your issue, but that some fluid was sucked into the air intake....
Regards,
Bill Pitman
I agree
That's a new one on me too. Check to make sure the coolant bottle cap is turned all the way to the second stop. Or Change your coolant bottle if it is actually defective.
it was fun while it lasted.
Yea ... I was thinking about changing the bottle out anyways just elevate that as the issue.
Good for you
Glad you could find the leak easily. 70 bucks does seem like a lot, considering how small they are, but I would buy the new one for sure.
Glad to hear that the mystery has been solved!!
(Even if it did end up costing you some cash...)
