Results 1 to 16 of 16
    Active Member nyfdtsdemt's Avatar
    Jul 2008
    Wilmington, NC
    Default Time to switch out my guage on the RT
    I here you can disconnect the gauge and the digital panel takes over
    so what can i put in those two holes if i take them out?????
    HM1 Nathaniel V. Mitchell, USN, CC-NREMT-P
    I believe that there are blanks you can use, to fill in the empty spots.
    I believe that there was a thread bouncing around in the RT shop talk area just a little while ago.
    With some research; you should be able to find it.
    EDIT: It wasn't in there... I'll keep trying to find it for you...
    May 2013
    Stanton, ca
    You have to unplug both gauges to get the digital display.
    This is what I put in one side. A digital volt gauge.
    http://www.spyderlovers.com/forums/s...ighlight=gauge
    On the other side I have a RAM mount right now but plan on putting a compass there as soon as it arrives.
    Bob
    2011 RT-S SM5 - Black
    Idaho
    Quote Originally Posted by nyfdtsdemt View Post
    Picture of wife in one, girl friend in the other?
    2014 Copper RTS
    Active Member Omcge's Avatar
    Sep 2013
    Mansfield Texas
    Clock and voltmeter
    2015 RTS Ltd Spyderpops bumpskid, Dual Isci Hand Brake ,Baker Wind Wings
    2016 Polaris Slingshot SL
    Very Active Member samewok's Avatar
    Oct 2011
    Jacksonville,Ar
    Volt meter and dual USB.
    4" Stubby antenna, Dual arm LEDs Fender LEDs, Back Rest, Luggage Rack, Run, Brake and Strobe for top case, Mirror LEDs,Back Off decal on mud flap, reciptal for Battery Tender and Heated Gear, mirror LEDs that stay on or work with blinkers, GPS, side bag red LEDs, Top cuff with Ram Ball phone holder And USB power, Top cuff with drink holder and passenger cup holder. Also grilles in front of radiators, also spyclops. Garmin 595 GPS, Freedom windshield. Also glove box console And trunk wrap in carbon fiber from wrap my spyder. BRP comfort seat. added garage opener with rocker switch in center console to match other switches. And I have added Elka stage 2 shocks.
    15 rt , yes Black
    Very Active Member Larry rt's Avatar
    Jul 2013
    Vestaburg Michigan
    Registered Users ursamajor35126's Avatar
    USA, Alabama, Leeds
    Quote Originally Posted by samewok View Post
    +1 on the volt meter and dual USB (from SL Vendor JT's machine shop)
    2014 RT Ltd Black Currant, Bump Skid, TricLed 3rd, 4th and 5th Brake Light with Modulator, TricLed Safety Bundle Led's and Reflectors with flasher option, TricLed Vader lights, JT's dash mount and USB outlet. Baker Wings belt tensioner and Drivers cup holder. Lamonster's FFP highway pegs and IPS, BRP Trailer hitch with Bushtec pin and 2007 Bushtec Roadster GT trailer. Volt Meter. Baja Ron Sway Bar. Doc Humphry's spring spacers
    Mike
    Active Member KennW's Avatar
    Oct 2013
    Gold Coast QLD Australia
    Quote Originally Posted by finless View Post
    Bob
    You must have a different wiring system in the States if you need to disconnect both gauges to allow the fuel and temp digital indicators to show.
    Every RT I've had anything to do with or discussed with owners on the subject indicate only a single gauge needs to be disconnected for digital gauges to start working.
    Oct 2013
    Forgot to add once a gauge is disconnected "both" gauges stop working.
    May 2013
    Stanton, ca
    You are correct somewhat. I did a experiment on this trying to see if I could keep the analog temp gauge working but remove the fuel gauge.
    If you disconnect the temp gauge but leave the fuel gauge, the digital display will not switch. If you unplug the fuel but leave the temp gauge, then you will get the digital display but the temp gauge pegs.
    This is on a 2011 RTS.
    Bob
    Registered Users Madrebel's Avatar
    Jun 2015
    Jackson, MS
    Quote Originally Posted by WasWinger View Post
    Active Member Empty Pockets's Avatar
    Apr 2013
    Monument, Colorado
    [QUOTE=finless;plan on putting a compass there as soon as it arrives.
    [/QUOTE]
    What type of compass digital?
    Bryan
    Very Active Member Pennyrick's Avatar
    Feb 2011
    Loganville, ga
    Lot's of choices. Here are mine.
    Penny and Rick have owned many motorcycles starting in 1974 with Honda’s, then to Suzukis, Gold Wings and ultimately Spyders.
    ‘74 Honda 360T (pair); ‘78 Suzuki GS 1000 (pair); ‘’82 Honda Aspencade; ‘84 Honda 400; ‘87 Yamaha 1100; ‘99 Honda Valkyrie; ‘01 Suzuki Burgman(triked); ‘02 Honda GL 1800(triked); ‘10 Spyder RTSE; ‘11 Spyder RTSM; ‘12 Spyder RTSL (pair); ‘20 Spyder RTL (current)
    Registered Users yamahog's Avatar
    Jun 2012
    Vernon Texas
    Default USB
    Here is what I replaced mine with, now maybe my gopro will stay charged for the trips. and only cost me $20 and some time with the dremel
    Ram mount on both upper air deflectors custom ram mount for ATC9k action cam
    Chrome Dear Whistles
    Dual Color MagicFLEX® Channelz finder lights
    TIPZ units
    CAN AM SPYDER RT RADIATOR UPPER BLOCK OFF PLATE
    CAN AM SPYDER RT RADIATOR LOWER BLOCK OFF PLATE
    CATALYTIC CONVERTER SHIELD
    TITANIUM EXHAUST WRAP
    JT's AIR FILTER KIT
    Albion,Michigan
    Default A Ouestion on your Your Thread- Time to switch my guage on the RT
    What gauge are you switching out, and what year is your Spyder. Thanks Dave
