I believe that there are blanks you can use, to fill in the empty spots.
I believe that there was a thread bouncing around in the RT shop talk area just a little while ago.
With some research; you should be able to find it.
EDIT: It wasn't in there... I'll keep trying to find it for you...
On the other side I have a RAM mount right now but plan on putting a compass there as soon as it arrives.
Bob
2011 RT-S SM5 - Black
I here you can disconnect the gauge and the digital panel takes over
so what can i put in those two holes if i take them out?????
Picture of wife in one, girl friend in the other?
4" Stubby antenna, Dual arm LEDs Fender LEDs, Back Rest, Luggage Rack, Run, Brake and Strobe for top case, Mirror LEDs,Back Off decal on mud flap, reciptal for Battery Tender and Heated Gear, mirror LEDs that stay on or work with blinkers, GPS, side bag red LEDs, Top cuff with Ram Ball phone holder And USB power, Top cuff with drink holder and passenger cup holder. Also grilles in front of radiators, also spyclops. Garmin 595 GPS, Freedom windshield. Also glove box console And trunk wrap in carbon fiber from wrap my spyder. BRP comfort seat. added garage opener with rocker switch in center console to match other switches. And I have added Elka stage 2 shocks.
+1 on the volt meter and dual USB (from SL Vendor JT's machine shop)
2014 RT Ltd Black Currant, Bump Skid, TricLed 3rd, 4th and 5th Brake Light with Modulator, TricLed Safety Bundle Led's and Reflectors with flasher option, TricLed Vader lights, JT's dash mount and USB outlet. Baker Wings belt tensioner and Drivers cup holder. Lamonster's FFP highway pegs and IPS, BRP Trailer hitch with Bushtec pin and 2007 Bushtec Roadster GT trailer. Volt Meter. Baja Ron Sway Bar. Doc Humphry's spring spacers
Bob
You must have a different wiring system in the States if you need to disconnect both gauges to allow the fuel and temp digital indicators to show.
Every RT I've had anything to do with or discussed with owners on the subject indicate only a single gauge needs to be disconnected for digital gauges to start working.
You are correct somewhat. I did a experiment on this trying to see if I could keep the analog temp gauge working but remove the fuel gauge.
If you disconnect the temp gauge but leave the fuel gauge, the digital display will not switch. If you unplug the fuel but leave the temp gauge, then you will get the digital display but the temp gauge pegs.
This is on a 2011 RTS.
Bob
Here is what I replaced mine with, now maybe my gopro will stay charged for the trips. and only cost me $20 and some time with the dremel
Ram mount on both upper air deflectors custom ram mount for ATC9k action cam
Chrome Dear Whistles
Dual Color MagicFLEX® Channelz finder lights
TIPZ units
CAN AM SPYDER RT RADIATOR UPPER BLOCK OFF PLATE
CAN AM SPYDER RT RADIATOR LOWER BLOCK OFF PLATE
CATALYTIC CONVERTER SHIELD
TITANIUM EXHAUST WRAP
JT's AIR FILTER KIT
