Battery tender install
What is the install sequence for permanently installing the tender to the battery?
Thank you
2015 F3S SE6
You don't stop riding because you get old, you get old because you stop riding
Thank you
My 14 RS-S came from the dealer [ Honda of Winston_Salem ] with battery tender installed. To install, find your battery, disconnect the negative terminal, then the positive terminal. Now install the positive battery tender lead and the spyder positive lead to the + Battery terminal. Now connect the - battery tender lead and spyder - lead the the Negative battery terminal. Then reprogram your display. Or, follow the instructions supplied with the Battery Tender. My Battery Tender lead just sticks out from behind the battery door. So when the ride is over I open the Fronk, attach the Tender lead lower the fronk lid, but not latch it. Then I am ready for the next ride. Good luck.
If I can't fix it, I will fix it so no one can fix it. Sypder Loco!
Why not just switch fuses & plug it in to the 12v outlet in the rear trunk? Much simpler, has worked just fine for me the last two winters.
already installed
2015 F3S SE6
