Page 1 of 2 12 LastLast
Results 1 to 25 of 46
Thread: gas mileage
    Jun 2015
    Central Arkansas
    Default gas mileage
    I know the Spyders aren't known for great gas mileage and I just got mine today so a couple of "Newby" questions, so be kind please. LOL I read that the tank holds 6.6 gallons. When I picked mine up it was near the red on the gauge. It would only hold about 4.7 gallons before the pump shut off. I rode quite a bit after that and the gauge got back down to the "red" and I filled up again and, again, it only took about 4.5-4.7 gallons to fill up. I had ridden only about 120 miles. Questions,,, is that normal to only take that little to fill up? Is there that much left in reserve? I feel like my mileage sucks but then again my trike only has 2200 miles on it (2011 RT-S) so it might not be completely broken in. I hope that when I get used to the proper shift timing my mileage will improve. What are you guys and gals getting?
    Very Active Member Purple Guy's Avatar
    May 2013
    Edmonton Alberta, Canada
    I've kept track of my mileage since my first tank of gas.
    I log my fill ups at Fuelly.com
    Here's a few stats from my 49 fill ups...
    7842 Miles - 12,620 Kms
    All time avg 35.6 MPG - 15.1 KM/L
    Last Tank 39.8 MPG
    Best Tank 41.0 MPG
    Last 10 fill ups...
    Date Miles Gallons MPG
    15-05-31 193.37 4.861 39.78
    15-05-31 121.66 3.556 34.21
    15-05-27 221.71 6.057 36.60
    15-05-23 212.14 5.887 36.04
    15-05-18 199.09 6.148 32.38
    15-05-09 84.20 2.795 30.12
    15-04-21 198.65 5.882 33.77
    14-10-20 177.71 5.312 33.45
    14-10-19 180.63 5.485 32.93
    14-10-04 101.35 3.181 31.86
    2014 RT-Ltd , Cognac
    The fuel gauges have historically NEVER been all that accurate...
    When I had my 2010 RT; I'd plan my fuel stops for right around 135 miles or so, and I'd normally take just over 4 gallons. (Usually about 33 mpg...)
    An awful lot of it has to do with how your right wrist "dances with the loud grip".
    Most of us have gotten used to using the trip odometers as the basis for fuel stops. I would always use "Trip A", for fuel stops, and save "Trip B" for accumulated mileage totals... The fuel gauge itself, was almost NEVER looked at...
    Greenville Tx
    Has anybody here ever intentionally let their spyder run out of gas to see how much it takes on the refill and how many miles can their spyder go on a tank? You could take a gallon along for when it happens.
    2017 F3 Limited
    That actually HAS been done...
    Search the fuel mileage threads; it's in there!
    Apr 2012
    Newnan, GA
    Quote Originally Posted by AY4B View Post
    I was riding with a friend this weekend that has a 2010 RSS Spyder and her husband had to catch up to me to let me know she needed gas soon. I don't remember how many gallons it took, but she said she had been on no bars for awhile. I know the 2013 RS I'm borrowing if I fill up soon after the light comes on, it's usually just a little over 4 gallons to fill up so it's holding about 2.5 gallons in reserve on the light. It seems to be pretty consistent on the volume and the fuel indicator, so it really just depends how comfortable you are traveling on the fuel light.
    BlueLghtning - Follow me on my SPOT Messenger
    Mine: KTM 650 ADV (Katuki), 09 DL650, 08 WR250R
    Hers: 07 Ninja 650R, 13 CRF250L
    Smugmug Pics - Save $5 <-- Click Here
    Nov 2012
    North Las Vegas, NV
    Last trip I checked on our RT was 29 mpg. I went 142 miles took 4.8 gallons. Do not try to squeeze more gas in after the nozzle kicks off. If you want more peace of mind get one of these:http://www.reda-innovations.com/
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
    Idaho
    My experience is dry tank to gas overflowing is right at 6 gals. About 20 miles after last bar goes off.
    2014 Copper RTS
    Very Active Member Firefly's Avatar
    Feb 2009
    Ceresco, Michigan
    Don't trust those REDA gas cans!
    Had one leak fumes and gas on me while on a long trip. All my clothes smelled like gas for the rest of the trip.
    When I contacted REDA they said they had some defective caps go out. To me this was unacceptable. Left the REDA at a gas station near Boston.
    Spyder #1 - 2008 GS SM5 Premier Edition #1977. RIP after 80,000 miles.
    Spyder #2 - 2012 RT SM5. Traded in after 24,000 miles.
    Spyder #3 - 2015 F3 SM6. Put 13,000 miles on and sold it.
    Spyder #4 - 2017 F3 SM6. Too good of a deal to pass up!
    I would caution that one bad experience with them; doesn't mean that they're ALL bad...
    Default Welcome..!!
    keep an eye on who is posting what mileage. The new 1330 ACE engines get much better mileage and have a different tank capasity. Most RT owners (998 twin) have disconnected the fuel and temp guages because they aren't that good. When you do this the fuel and temp appear on the panel digitized. They replace the dash guages with outlets or other guages (voltmeters, ampmeters, oil pressure etc). The best way to know is to run out of gas but also know the tank does not hold 6.6 gallons. There is air space and the most I have gotten ,without running out of gas, was 5.4 gals. Also remember the different model 998 twins get different mileages. Mine is an RS
    ​2012 RS sm5
    Nov 2012
    North Las Vegas, NV
    Agree.
    Been using mine for 4 years in the saddlebag. I don't keep clothes in the same bag though. Rain suit, tools, mini air compressor, tire plug kit, extra oil. There is a slight smell but nothing overwhelming.
    2016 F3 Limited
    2019 Ryker Rally
    2020 CSC TT 250
    Central Oklahoma
    I put 6.001 in my last tank for a 2014 RT-S and I had been on E for quite a while. If I remember the manual correctly, it's only a 6.1 gal tank.
    2020 RT Limited , Petrol Metallic Dark
    Jul 2011
    Mitchell, Ontario, Canada
    All models 2013 and earlier have a fuel tank capacity of 25 L or 6.6 G
    2014/15 RS and ST models have fuel capacity of 23.5 L or 6.2 G
    2014/15 RT models have a fuel capacity of 26 L or 6.9 G
    2015 F3 models have a fuel capacity of 27 L or 7.1 G
    2018 F3 LIMITED
    Thanks, Billy!
    Wasn't it determined, that the useable tank capacity for the 2010 to 2013 RTs was just about 6 gallons?
    Jul 2011
    Thanks, Billy!
    Depends on how you fill it. Couple weeks ago I drove into the gas station with no bars for a while. Took 24.2 L that's 6.39 US gallons. So i don't think the 6.6 gallon capacity rating is too far off.
    2018 F3 LIMITED
    Our experience from just a week or so ago.
    I failed to gas up on the 2011 at an appropriate point in our ride.
    The gas light always comes on at about 150 on this particular . The 2010 used to come on at 135.
    We went 178.2 miles and put in 5.5 gallons. That was 32.4 (32 mpg--on that trip).
    My longest on a 998 Rotax--180.4 and 5.8 gallons. That is 31.1 (31 mpg for the trip). It is a bit scary when the fuel gage is on empty or below. We always set mileage odometer A to zero at every fill so we know how many miles on the tank. Most fills are at the 150 mile marker.
    My experience with the 1330: The gas light comes on between 200 and 205 miles. I get between 39 - 42 mpg--depending.
    Active Member WEB-WVR's Avatar
    Sep 2009
    Albany, Oregon
    When I first looked at Spyders back in 2008-2009, for me an avid motorcycle rider....the small gas tank and poor mileage was a real negative. I just purchased a Spyder this April....the negative still remains.
    IMO: The Spyder needs a larger fuel tank. A bike designed for touring with such a small tank makes no sense. Second, the design engineers at BRP really need to work an better fuel efficient engines... some cars weighing 2-3 thousand pounds get better mileage.
    Still lovin the
    Craig From Albany Oregon
    Very Active Member Big F's Avatar
    Aug 2012
    Bellevue, NE
    Quote Originally Posted by Purple Guy View Post
    Last Tank 39.8 MPG
    Best Tank 41.0 MPG
    Last 10 fill ups...
    What is your take on why the last tank had the best mileage??? getting 39+ is awesome!! I usually get low to mid 30's when I check mine (2014 RT Limited)
    BIG F
    It might just be the dance that your right wrist is doing with the loud grip...
    Jul 2014
    Mint Hill, NC
    Default It Must be the Cognac Color
    Purple Guy and I are close. Through 7,440 miles my average is 36.0, best tank 40.5 and worst tank 32.2.
    otherwise be a vulgar brawl.
    Cognac 2014 RT-S
    2010 RTS-SE, Orbital Blue
    Sep 2009
    illinois
    Quote Originally Posted by Big F View Post
    BIG F
    When you get to the trip odometer screen, look at the top corner on yhr right side and it gives you average mph for that tank of fuel. Do that a few times and you should be able to find the "sweet spot for your bike.
    Member Stranger1759's Avatar
    Apr 2015
    Tonganoxie, Kansas
    Default How do you get the most MPG out of your Spyder?
    So what is your trick get to get the most MPG?
    Always shift @ what RPM?
    Avoid speed's over what MPH?
    Any other thoughts?
    I know that RPM, shift points etc... depend on motor size and transmission variable's.
    Active Member Leslee's Avatar
    Jun 2011
    Apex, NC
    On my 2011 RTS-SE, I averaged about 30 mpg. I used Trip A for tracking when to get gas--usually 120 - 140 miles. I usually got only 4 - 5 gallons in. Rarely had fuel light come on. One time when it did, I went 20 miles before finding a gas station.
    2014 Cognac RTS-SE6 & RT 622
    1993 Teal Gold Wing SE
    Very Active Member robmorg's Avatar
    Oct 2013
    Pottstown, PA
    Quote Originally Posted by bensallen View Post
    That's about 25.5-26 mpg. I'd say that is typical for an RT with the V-twin engine. I've NEVER been able to get more than 25.5 mpg out of mine - mostly it's closer to 25. I know folks here have reported better mileage on RT's with the 998 engine, but I sure don't know how they do it.
    As others have said, the fuel gauge is not accurate at the lower end. But there should be about 6± gallons of usable fuel in the tank on these models, so at 25 mpg, that would take you 150 miles. In my case, I certainly would not go beyond 140 miles without getting more fuel, and then only if I knew I started out with a very full tank. That would give me a very small margin of safety.
    Rob
    2013 RT Limited
    My "Mods & Farkles" Link
    May ALL your roads be beautiful
    Greisemer's Mill Bridge, Oley, PA
    2013 RT Limited , Lava Bronze with Antler Brown Seat
Tags for this Thread
