Opinions on yokohama s drive please.
I am most interested in your opinions of its performance in wet weather conditions.
We ride 2 up 90% of the time, and even though the Kenda wore quickly for sure, I will say I was impressed with its performance in general, but especially in the rain, even with minimal tread present.
Thank you.
Lets ride!!!!
formerly pman2011
Thank you.
I have the S drive and rode in the rain for 400 miles and the Spyder performed great, no wheel spin at all. If this tire will last at least 25000 miles I will be buying it again.
[B]
2018 Intense Red F3T (See About Me under My Profile for mods)
2010 Timeless Black RT-622 Trailer
2014 Timeless Black RTS-SE6, 34,300 Miles, traded May 2019
2011 Timeless Black RTS-SE5, 15,180 Miles, traded April 2014
Don't know..!!
Still happy with Kenda (old compound) I got great mileage on my 2012 second one doing great. But have noticed a trend towards the yokahama. The kuhomo has been reported to hydroplane some and many stores won't sell them for spyders. Those using the yokahama seem to be happy with the performance but haven't seen mileage reports.
Gene and Ilana De Laney
Mt. Helix, California
2012 RS sm5
Thanks for your opinion,
I appreciate the feedback.
Lets ride!!!!
No Kuhomo for me for sure, I have read too many hydroplane complaints
I am leaning towards another Kenda, but the S Drive seems to be a quality all around product.
Lets ride!!!!
Go for it and let us know what you find. Many mention what they use but not how they perform. ..
2012 RS sm5
ACCORDING TO TIRE RACK
2016 Spyder F3 Limited Steel Black Metallic
Lamonster approved LED Headlights
Lamonsters LED Fog lights
BRP Driver & Passenger backrest
BRP Trailer Hitch
Shamrock Black & Polished
Signature light
Elka front shock's
Rolo Laser Alignment
Dual Power outlets
Garmin 590 GPS
I put the Yokohama on my 2014 this week and I am hoping that it will handle great in the rain. I was torn on whether to go with a Kenda for my trip to Alaska but decided to give the Yoko a go. I put so many miles on my Spyder that I'd be changing Kendas out every other month. I'm hoping that the Yokohama will last long.
The tread pattern on it is very similar to that on the Kenda and the Arachnid.
2014 RTL-SE6 8,600 miles
2011 RTS-SM5 5,000 miles
2010 RTS-SM5 59,148 miles
2010 RT- 622
Well, Mike, your theory doesn't hold up because, believe it or not, YOU are one of the "POPULAR PEOPLE" here.
Could it be that the YOKO just has more favorable comments here than the Altimax? What most people here do, I think, is just read the threads and try to weigh the positive and negative comments about each tire discussed. It's easy to think that perhaps the dealer survey/stats may not entirely apply to us, because tires may perform differently as one of four on an automobile, than they would as the only tire on the back of our Spyders. (For example, I'd bet that with that deep "V" cut, the Kumho AST sheds water pretty well on an automobile, but folks say that it it doesn't grab the wet roads as it should on the Spyder.)
i think you hit the nail on the head.
2010 RT- 622
I have just installed my 3rd Yokohama S drive on the rear of my '08. I also have them on front. I didn't switch to them for longevity but rather performance, wet and dry. They are a soft compound that sticks to the road well. That being said they may not last as long as some others but I'm not a long distance rider most of the time. Better handling and safer especially on wet roads. I buy two for the front and two for the back as I usually wear the rear at twice the rate as the front. I don't roast my rear tire for fun but I do like to keep good tread under me and my precious cargo, my wife. I have never hydroplaned on my Yokohama like I have with the Kendra. I haven't looked at the Altimax Rt-43 but I will check it out. Ride safe and have fun out there. Dennis
"Stupid is as Stupid does"
Don't Drink and Drive or Ryde!
Each Day is a Gift
Mike, I was unable to find on Tire Rack where they tested the Yokohama S Drive against the General rt43. The two tires have been tested, however each was in a different test compared against other tires.
I find it difficult to believe that a firmer compound touring tire will outperform a summer rated ultra performance tire.
The General rt43 in the size you recommend has a rating of 600 on treadwear, an A rating for traction in the wet (stopping) and a B temp rating.
The Yokohama S Drive in 205/55R15 rates as 300 on treadwear, gets a AA rating for traction and for temp and A rating.
I may be wrong, but unless compared side by side I just find it tough to see a touring tire out running a performance tire.
PK
when my present tire goes south... I plan to buy either a Yokohama S Drive or General Altimax ..will not consider a "2 ply Crapenda" for my ride..
osm
TIRE TESTING ETC.
PK
Paul, Tire Rack doesn't do testing like the way Car & Driver does --Vette vs Jag vs Porsche etc.----nor do they test Tires against each other based on traction " A " vs " AA " vs " B " etc..........and the testing is not all from the same vehicle, on the same road, in the same weather conditions etc......it's not like " DYNO " results......But I will tell you this, I just found a sticker ( from a tire purchase ) in my garage. It was from a GENERAL ALTIMAX RT .......and I remember this was the tire I had on my RSS that I drag raced at Spyderfest 2013 ( at a real 1/4 mile track ) and won 1st place in class, plus in the shoot-off I think I ended up 3rd overall.......So I think that TIRE had some TRACTION .....(and it was only the 205/60 version )....Mike
WELLLLLLLLLLLLLLLLLLLLLLLL ??????
...Thankyou rob, ....But I honestly think you are confusing " POPULAR " with " CONTROVERSIAL ".....or worse " INFAMOUS " ........Mike
FWIW, the test I read compared 4 tires in each test against each other. All were in the same type if not the same car, over various terrain and the same route for each. Going further, both the S Drive and Altimax rt43 seemed, per the description, to be tested on the same type of vehicle over the same course they use.
If you compare both rating charts, the touring tires score very well, and even exceed the performance tires. This almost would seem to indicate that the standards of the tests differ depending on the tires intended use.
I am sure the girl can ride. Just not sold that the Altimax rt43 is a better performing tire on a Spyder.
In regards to drag racing your machine. It is cool that you were on the top box of the podium. As for tire performance, unless both machines had a huge amount of horsepower, the tires grip should be more than adequate with simply dropping the air pressure. I am going to caption your win as driver skill over machine traction or horsepower.
Our S Drive arrived yesterday. It will be a few weeks before I am ready to make the swap. I have no plans for seriously drag racing a 2up, loaded RTs, it will however be subjected to normal use, both in the dry, unfortunately in the wet, on hot roads during the day and cooler roads at night, with straights and curves. Simply time will tell if my choice was proper.
PK
I am interested how the Yokohama holds up and works. I want both a tire that grips and wears well. Time will tell on the Yokohama.
2016 F3 Limited
2019 Ryker Rally
2014 Suzuki V Strom 650
2020 CSC TT 250
I have 2K miles on my Yoko now and no real signs of wear I can tell yet.
Can't help with wet conditions as we are in a bad drought with little rain and thus have not been out in it yet.
But with that said, I really like the tire so far. No grip issues at all.
Bob
2011 RT-S SM5 - Black
Thanks for the
feedback, I appreciate it.
What size are you using?
Lets ride!!!!
I agree! You cant have grippy and long life, the two just don,t go together. I mean you can put a tire on Jimmie Johnson's car that will last the entire race, but he will in no way finish on the lead lap.
The S-Drive as well as the Federal Evo's have a "AA" wet weather traction rating. That is a ultra high performance rating, all the others just an "A" rating. So you can choose grippy or long life. That's your choice.
My Kumho (my current rear tire) is an A rating. I will try the S drive next and the Evo's for the front are already ordered.
BRP Trailer Hitch
Signature light
Elka front shock's
Dual Power outlets
Garmin 590 GPS
I'm not having a problem with a Michelin Primacy. 11,000 miles and still grips good. Had it in the rain and it was good. Hoping to get 20,000 but only time will tell. Right now it looks like a General Altimax RT43 will be next.
2016 F3 Limited
2019 Ryker Rally
2020 CSC TT 250
