So, as you all know mine was one of the Spyders that never had P/S from day one with no codes or other symptoms.
I took it in to the dealer for the new P/S unit as that is what BRP told my dealer would be needed for the fix.
Well..... they replaced the P/S units and... you got it, still nop P/S!
They finally ended up replacing my gear position switch and did a new download to the system and now it has power steering!
Seems that between a bad batch of gear position switches and a new software upgrade being needed, it was keeping my P/S from functioning yet showed no codes.
I was told that the gear position switch is going into the CanBus system and really messing up things big time other than just what position your transmission is in.
So, to any of you who like me had no P/S, maybre it's just a gear position switch and download away from working again?
MM
