SE5 Transmission Won't Downshift
Well Spyder fans, I am still trying to enjoy my Spyder but it won't cooperate. The latest glitch is still my transmission. I have ridden it 450 miles after a recent visit to my dealer and it still has a mind of its own. Now the problem is that it will not downshift when coming to a stop. I have to set and wait for the transmission to finally do its thing and get down to first gear. I try and manually downshift with no luck. Everyone lined up behind me at a stop sign has to wait for it to get into first gear. After about 30 seconds, it finally gets there and we can leave. Anybody else about ready to set fire to their SE5 in the dealers parking lot?
Pissed off in Tallahassee!!!!
Got 2000 miles on mine no se5 issues. Sorry and hope it gets fixed.
Make sure that you are COMPLETLY off the throttle when coming to a stop, it should start downshifting as RPMs drop. If this does not happen have dealer replace transmission control module under warranty.
downshift
had same problem today after backing up our of garage, went into an "E" mode amd took a few minutes to shift back into N and 1st.
Why?
There is a published "fix" for your problem that the dealer can find on BOSS-Web.
also make sure your not comming to stops at a high rate of speed too stopping to quickly will make it not downshift correctly either
Just curious, how many folks with SE5's haven't had any problems? BRP needs to step up.
problimatic se5's
I havent had any issues to speak of with my se5 since i bought on oct 17 of this year its ran killer and then all of a sudden it died yesterday. and i dont know why i guess i will figure that out soon as its fixed this week hopfully
This post addresses the SE5 shifting problem. http://www.spyderlovers.com/forums/showthread.php?t=8054
Called my dealer yesterday and they pulled up this notice. My parts are on order and they tell me it will take just a few days to get the parts and about 3 hours to install. I have over 4k miles and have intermittent shifting problems during the first thousand miles and again just recently.
My SE-5 has shifting problems
My 2008 SE-5 has shifting problems too, similar to the ones noted here. Mine will "lock" into a gear and not come out. Bad news when you are on the Interstate and have to try and keep up with traffic. I found out the hard way that the top speed in 3rd is about 35 mph. People around me did not appreciate it.
Sparrow
Sparrow
You have another problem if your top speed in 3rd gear is 35 i can do 40-45 in 1st gear easy.
But there is a service bullitin for the SE5 Shifting problems.
Very Helpful Member
Originally Posted by NancysToy
Are you sure it didn't also go into limp mode?
-Scotty
I'll be the third to agree with this. With my SM5, I have been well over 40 MPH in first. Maybe there is something in the SE5 that is limiting the speed.
Its not an SE5 thing because mine is the SE5 my guess is he was in limp home mode or had something else going on.
Too many SE5 problems...and they seem to continue...why bother with the headache? Save your money, go with a SM5...spend the extra cash on mods...
This happened to me yesterday came to a complete stop in 5th gear!!!! Never bogged down gave it some throttle and then shifted down
I guess that would be me (touch wood)
2500 kilometers and not a hiccup
My SE5 has 2300 miles on and no shifting issues.
Chris
Is this problem limited to the 2008 0nly?
There was a poll on one of the forums - if I remember correctly it was close to 50/50 problems vs. no problems with shifting on the SE5 -- not very encouraging. But with the warrenty and # of problems out there - a fix will be found and offered.
I love the idea of the electronic shifting, when they are working flawlessly I'll wish I had one
donzo,
No way for me! Part of the fun of the bike is hittin' the clutch and changing the gears. It's like an auto vs. manual car...manuals are much more fun, IMHO!
I like changing gears,turning knobs,pushing buttons and pulling leavers. Riding would be boring without.
Because some of us are disabled for one reason or another and don't have the liberty of shifting with our legs but we still want to be in the wind....
That's different...if you have a disability, then you go with what works, for sure...
Mine shifts down at 2500 rpm until it goes from 2nd to 1st, then it shifts at 1500 rpm. But as someone said, be sure you have totally untwisted your throttle when you know you are coming to a stop and leave it in that position as long as you are moving to your stop. When you do that, the downshifting will happen pretty quick. And talk to your dealer about the "fix" that BRP has authorized. Should be "no charge". I turned 5000 miles on mine today...bought on 11-18-08.
2008 GS SE5 in 2008
Traded at 43,000 miles for a left over
2010 RT SM5 in 2011
Traded at 57,000 for a left over
2014 RTS SE6 in 2015, which has 35,000 miles
Oct 19th, 2017, totaled 2014 RT while killing a Javaline
Dec 12th, 2017 drove a 2017 F3L home. What an awesome machine!
Never had any breakdown stranded issues.
Tags for this Thread
