Etiquette question?
Folks, when you are going to park near other bikes that are 90degrees to the curb, with the Spyder, do you park like the bikes (90 degrees) or parallel to the road? Do you back in like the bikes?
Why
I have reverse
Sucks to be them. They have to paddle
I back in just like the rest of them.
Cruzr Joe
I always back in and park 90 degrees (or at an angle) just like the other bikes. If there are no other bikes around, I"ll park parallel to the curb.
I usually park the Spyder like I would a car - unless I think it's safer to park somewhere else.
We're a lot longer than the typical "leaner". Be careful to not leave your nose out in harm's way...
I usually park the way the rest are parked.
Kind of depends on how much room there is to park. I generally park with protecting my spyder from whatever, but if room is tight I try and park as the other bikes are parked provided my spyder fits.
Thanks folks, that helps....
Nose first, show off high speed reverse!
Originally Posted by Bfromla
You park upside down? Wow!!!
Depends..!
if with other bikes I back in the same as the rest. If not I parallel park in the space alotted...
Simple
As stated by others, I simply back in..rear tire to the curb.
IT IS, WHAT IT IS...
This is also the way I do it.
Typical Spyder, hanging from the ceiling!
But do you park upside down, and on the ceiling?
I just do what the others are doing. However I have never been a with a group that parks on the ceiling so I do not know about that part. Parking by myself among cars, park as the space indicates
Oldmanzues
Oldmanzues
Directions for parking on the ceiling can be found in "Mary Poppins--tea party on the ceiling." You will get a real "laugh" from that one.
Or; you just need to "Get your PARTY on!"
