Tupperware removal manual??
I just got the Good 2014 RT manual from the guy on Ebay, but I don't see anything about removing the tupperware. Is there a manual somewhere that us lowly people can buy/get/ borrow?
Maybe that is why the dealers charge so much, their people learn by trial and error.
One of the hardest decisions you'll ever face in life is choosing whether to walk away or try harder.
Bill, each section will tell you what body panels you need to remove. In front everything starts with the mirrors. You need a 30 Torx for most everything, there are a few 10 mm bolts tossed in to spice things up, and of course a ton of push pins.
2014 RTL-SE6 8,600 miles
2011 RTS-SM5 5,000 miles
2010 RTS-SM5 59,148 miles
2010 RT- 622
A pair of push pin pliers is a very inexpensive but useful tool. I got mine from a Car Quest auto parts store because all the ones in my local Harbor Freight were junk with every pair having misaligned, jagged jaws.
otherwise be a vulgar brawl.
Cognac 2014 RT-S
The body panel removal is in there. Each according to its own section.
The manual is arranged by items. Pick a panel, look it up and it will tell you how. Starting with a list of items that need to be removed first. Start with the first one on the list, look it up and follow those instructions. They clearly show where each fastener is located etc. Part of the difficulty is knowing what the panels are called. None are called tupperware.....
Jay, a friend of ours had a pair of those that came with a Polaris tool kit, Joe tried to buy a pair at Polaris and they wanted way too much for them. Thanks for the heads up on Car Quest we will look for them there. Of course, a flat tipped screw driver works but Joe is from the school where the guy with the most tools wins.
2010 RT- 622
PUSH PIN TOOL
What I did was make your own. It is very easy to do by taking an old pair of needle nose pliers and grind down the tip and then notch them to make a tool that easily removes these pesky plastic rivets!
2015 an Am Spyder RT Limited
2013 Yamaha WR250R - Sold
2011 Can Am Spyder RT-S SE5 Limited - Sold
2011 Aspen Sentry Trailer
2003 BMW K1200LT - Sold
2007 Unigo Trailer - Sold
2001 BMW K1200LT - Sold
2001 Honda 750 NightHawk - sold
2015 RT Ltd , Canamspyderaccessories Brake pedal ext. Red
Hey, another member of my team! A guy can never have enough tools. They are Lisle and cost about $13. Junk Harbor freight were about $10.
Cognac 2014 RT-S
The one that Mike makes, work great!
it's easy, i had my bike apart a few times. just take your time
NO BIKE AT THIS TIME
THE TOOL.........!!!!
Been using a flat head screw driver because the harbor frieght one is junk. Have not found any other auto place that carries them around me. So I have been using a flat head screw driver which will work it's just a little fiddly
Bob
2011 RT-S SM5 - Black
Get a old paint can opener and bend the tip ................... works great.
Cruzr Joe
snap on also has numerous ones to fit all your needs and with
different hole sizes. i have the lisle and blue point ones too.--irv
my carquest guys have the lisle also,
2015 rts-white pearl- mods- '16 F3 fat 6 chrome wheels,
and some little stuff. setback utopia backrest, baja ron
sway bar, oem adj. air deflectors, marlin gps compass,
lamonster fbb foot pegs[modified brackets], lamonts
vibration damper, rock guard, and side case stiffener kit,
. brp comfort seat. , fomozas and
altimax, magic mirror mts, and wide mirrors.
[joyce & irvin toms]
How to save or find
Originally Posted by markyodo
How can I save this video or find it for later use?
Click the arrow top right when playing and it will give you a link to share. Mail it to yourself.
Jeff
Pragmatic Member
I got my push pin pliers on Amazon and they work fine.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Pam
- 2015 RT-S Special Series / Red & Black
- Baja Ron Sway Bar
- Utopia Backrest
- F4 Customs tall and wide vented windshield
- Stebel Super Loud Air Horn
- Baker Built Air Wings
- LaMonster Highway Pegs
- SpyderPops Exhaust Block Off Plate
- SpyderPops KOTT Grill
- SpyderPops Belt Guard
- Cat Bypass
- Laser Alignment by Squared Away
- TricLED Fender Lights
- General Altimax RT43 rear tire
- Dual flag holder
- Mud Flap
- A$$hole seeking missile system
Pragmatic Member
It's on Youtube
"https://www.youtube.com/watch?time_continue=1&v=zVulKP4_GaU"
Pam
- Baja Ron Sway Bar
- Utopia Backrest
- Cat Bypass
- Dual flag holder
- Mud Flap
does brp or someone else make a kit that includes extra torx headed
screws, bolts, push pins , and grommets? thought i read something on
here a while back. all the necessary items that walk off or drop into the
black hole of spyderdom.
call it a tupperware survival kit !
Spyderpops has the push pin package for sale, and Amazon has different choices for the tool.
https://www.amazon.com/gp/aw/d/B003W...?ie=UTF8&psc=1 thus is the pair i picked up work good.
Sent From my Note 5
What are they called and where to find them?
Originally Posted by PMK
With all this talk about removing body panels, everyone should make sure they have spares of the mirrors mounts and clips. The mirror mounts we often hear get broken when the mirror is removed. Buy spares and keep them in the Spyder, you never know when you will need them...
That sounds like a great idea, especially since every time I take something off I'm holding my breath, but where can I find them, and what am I looking for? I get the feeling that if I just walk into a auto part or hardware store and show them a picture of the clip, they're gonna scratch their head and say "you want what?"
GWRRA Virginia District Director. Because we don't care what you ride, just that you ride safe!
Tri Axis Handlebars / CB & upgraded antenna / GPS & Cell phone integration / Trailer Hitch / FOBO TP Monitors / Black & Pearl Ultimate seat
Spyder Cuff / Custom Paint / Laser Alignment / Flag Poles / 3rd & 4th Rear Brake & Turn LED's / Gear Brake Decelerometer Module
A whole bunch of lights from LaMonster and SpyderPops
