12 v power outlet
Hello SpyderLovers,
We have a 2014 RT-s and just finished a 1200 mile trip. All went great except our Garmin battery ran out mid day trying to get from Bishop,ca to Solang, Ca.
There is a round "cover" on the left hand side of the passinger arm rest area.
Can this be used for a 12 volt outlet??
I know there is one close in the back trunk but my wife wants one where the "cover" is. One on the dash isnt suitable for us.
Has anyone put a 12v outlet here???
Kaos
yes you can do that or there is a button on the console right above the glove box (where the buttons are .. parking brake, heated grips, etc ....)that could be used. the easiest thing would be to add one somewhere on the dash (you get to drill) or if you are not using one of the two gages on the dash, it could be removed and you could add a USB using a kit from JT. He is a sight sponsor on here and has some great stuff.
i've seen some that took the speaker grill out and drilled it out to hold their adapter. I think that grill is about $8 so if you screw it up, you are not out that much money.
JT
Tried to find a link to JT------- I'll keep trying but if anyone knowes it could you post up??
Kaos
Kaos
You can look at this link will help you
http://www.spyderlovers.com/forums/s...923#post888923
Originally Posted by hobbykim
what wires do you tape on the passenger left rear plug. I want to add 12 volt outlet. thanks Ron
Tags for this Thread
