Page 1 of 2 12 LastLast
Results 1 to 25 of 28
Thread: desperate
    May 2015
    United States
    Default desperate
    I switched from 2 to 3 wheels over a year ago (left AK amputation long time ago).
    Well, the Spyder RS-S SE5 was the ticket. Rode it several long trips.
    About 6 weeks ago, preparing for a 2k trip, it went to "Limp mode."
    ABS Fault
    VSS Fault
    Check DPS
    Took it home and pulled codes --- "no active codes"
    After about ~5 miles later it went back to limp.
    Pulled codes while engine light was blinking:
    C0044
    P2545
    U0122
    Took it to the local dealer (Team Mancuso Powersports SW) .
    6 weeks later, they still have no clue, other than there must be s a wiring problem.
    All that @ $99/ hr.
    I asked them to give me a trade-in for a F 3, but the can't figure what to give me for my RS.
    What to do?
    Check your battery connections... The DPS is the single largest consumer of power, and it often gets... cranky, when it starts feeling shortchanged...
    Otherwise; could you have had some critters chewing on the wiring?
    Very Active Member jwulf74's Avatar
    Jul 2013
    Piedmont, SD (Black Hills)
    Did they check the battery or is the battery fairly new like under 3 years old? When my wife's battery started to die it would do weird stuff like that. New battery too care of it.
    2017 Can Am Commander Limited
    2012 Cadillac CTS-V Black Diamond
    2020 F3 Limited Magma Red (miss the 2011 Viper red)
    2010 RT622 - Black
    It could be a simple thing like loose battery connection or bad battery.
    I believe your dealer name has come up before--similar stuff.
    6 weeks and they don't have a clue, can't or won't help you to get a different Spyder
    Try a different dealer if possible.
    Same thing happened here with the "other" dealer. Friends had same issue with their new RT. Dealer could not figure anything out. Was on a fix one issue at a time until they figure it out. (Two weeks per issue).
    They took it to the other dealer finally. Loose battery connection and all is now well.
    Active Member Tx web rider's Avatar
    Jun 2011
    Aransas Pass Texas
    Default limp mode
    just a question did you happen to replace any lights in the brake area
    mine did the same thing after I placed LED brake lights in it
    removed them and have no more problems from that
    Jun 2010
    Las Vegas
    What year is your RS?
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    May 2015
    United States
    Spyder is a 2011 RS-S SE5 with ~5k miles.
    Battery, lights, fuses, BLS all have been checked and passed.
    I don't ride the brake.
    Coincudence or not, I installed the saddlebag kit just prior.
    No other dealer in town but there are 4 locations.
    Very Active Member oldgoat's Avatar
    DDO, Montreal Island
    Quote Originally Posted by hancycle View Post
    You say some items have been checked. By yourself?
    If not, I would remove a couple of panels & check the battery connections myself. A lot of dealers will say they have checked things just to keep you quiet.
    Charge the battery while you have the panels off. Buy a Battery Tender Jr & permanently connect a pigtail so you can easily connect the Battery Tender when the Spyder is not in use. Make sure the battery terminals are clean & tight.
    2008 GS SM5, Full Moon Silver
    2007 Piaggio MP3 - 250cc
    A four year-old battery...
    I'm starting to suspect it even more.
    Have you had it load tested?
    Jun 2013
    queens ny
    hijack,,,,,,, i am desperate also but not over my bike
    NO BIKE AT THIS TIME
    Very Active Member CanAmChris's Avatar
    Feb 2011
    Near Philly, PA - USA
    Quote Originally Posted by oldgoat View Post
    ...Buy a Battery Tender Jr & permanently connect a pigtail so you can easily connect the Battery Tender when the Spyder is not in use. Make sure the battery terminals are clean & tight.
    Oldgoat speaks truth. The last thing I do after getting off either of my bikes is hook up the tender, then I head inside. Nothing like a nice green battery tender light in the morning.
    Jun 2011
    Aransas Pass Texas
    Default limp mode
    double check your rear light connections I know its a pain
    but last thing you did was install the hard bags I would go to that
    May 2015
    United States
    All things mentioned have been done by the dealer tech.
    One thing comes to mind.
    When I hooked up a pigtail for the battery tender I could not unscrew nor tighten the negative connection near the rear fuse panel. Whatever this bolt screws into (well nut?) turns. That was a year ago.
    I think I will mention this to the service people.
    There is a nut on the end of that bolt but it is "very" difficult to access. I had to try a lot of wrenches before I found one that would go on the nut. It is just as important to have that one tight as the battery terminals as it is part of the ground circuit.
    Good luck getting your eye on the nut & being able to tighten it.
    May 2015
    United States
    Default Resolved
    Called earlier this week and left a message for the tech that I know there is a bad battery ground connection (ground post under the seat next to the rear fuse box). Nut in the back turns and I could not re-tighten it. Did this a year ago.
    Called back yesterday to find the message was not passed on. This time I got the right guy and informed him of what I know.
    They called me back 2 hrs later and told me they found the problem: a broken wire in the brake system. They will charge me for 6 hrs labor (@ $ 99/ ).
    Mhhh. What a coincidence.
    Well, at least it's fixed. I just have to believe what they tell me.
    Thanks for all your input, especially the advise of checking for poor battery/connections.
    Glad to hear that you're back, and "up on three" again!
    Please keep us informed; it'd be nice to know if this solves ALL of the problems!
    Glad it all seems to be ok now.
    Trade your dealer, not your Spyder!
    Very Active Member robmorg's Avatar
    Oct 2013
    Pottstown, PA
    Great to hear that the problem was resolved for you!
    But now you have another problem... You have to decide whether or not you still want to trade it in for the F3.
    Rob
    2013 RT Limited
    My "Mods & Farkles" Link
    May ALL your roads be beautiful
    Greisemer's Mill Bridge, Oley, PA
    2013 RT Limited , Lava Bronze with Antler Brown Seat
    Invalid Emails
    Nov 2012
    Lawrence, Kansas
    Dealers are great. Some better then others but it sure seems like if you have a problem it's best to run it by the people here on Spyderlovers. Seems they almost always get it figured out with all the brain storming.
    Scott
    Very Active Member flaggerphil's Avatar
    Mar 2012
    Florida Space Coast
    Did they have your bike for six weeks? That alone would send me looking for another dealer.
    Phil
    I may be old, but I got to see all the cool bands.
    2011 Spyder RT-AC
    Very Active Member SPYD3R's Avatar
    Apr 2011
    GREENVILLE, SC
    Default BOB IS RIGHT
    BOB IS RIGHT..........i was get'n code up da Ka-Zoo on my RS..... checked every freak'n thing with a meter.... NOTHING...
    couldn't find a 'fault'.... started to and decided 2 call
    BIG BIRD in AZ..... he told me 2 check my battery connections..... BINGO...... tightened the connections, and PROBLEM SOLVED.....
    DAN P
    SPYD3R F3-S
    Oct 2013
    Pottstown, PA
    Dan,
    That was very wise of you. You can indeed learn a lot from BIG BIRD. My son watched him religiously when he was three years old, and now he is the president of his own technology corporation earning Big Bucks.
    Rob
    2013 RT Limited
    Apr 2011
    GREENVILLE, SC
    Default NOT
    Quote Originally Posted by robmorg View Post
    Dan,
    i'm think'n we're NOT talk'n 'bout da the sameBIG BIRD......
    my BIG BIRD lives in AZ, and is 67 yrs old, all beat up, and worn down, and grumpy n mean as a cobra with athlete-foot....
    but still a hell'a'va nice guy in my book...
    dp
    May 2015
    United States
    I think I do both.
    Trade for a F3 at a different dealer.
    Registered Users donkes's Avatar
    May 2015
    VA
    Get rid of the dealer and post on the internet. these are not cheap machines.
