front fender shaking
has anyone ever had one of their front fenders do a very noticeable shake when applying brake pretty heavy.............. no steering issues or vibration issues to be felt but when applying brake hard,,,,,,,,,,, left fender is stationary but right fender shakes very noticeable .
My guess: You've got some mounting bolts, that could use some attention from the proper wrench...
I'd say either the bolts are loose or you have a warped brake disc.
Penny and Rick have owned many motorcycles starting in 1974 with Hondas, then to Suzukis, Gold Wings and ultimately Spyders.
74 Honda 360T (pair); 78 Suzuki GS 1000 (pair); 82 Honda Aspencade; 84 Honda 400; 87 Yamaha 1100; 99 Honda Valkyrie; 01 Suzuki Burgman(triked); 02 Honda GL 1800(triked); 10 Spyder RTSE; 11 Spyder RTSM; 12 Spyder RTSL (pair); 20 Spyder RTL (current)
I would have also thought that the rotor was a possibility, but she said that there was no vibration...
I agree
As I see it..!!
with all the lighting work done I would start with checking the mounting of the fender. Does the fender wiggle at any other time..?? abs kicking in should make both sides do the same and bend disc would be felt as a lobbing in the pedal..
2012 RS sm5
if you come to new york i would be glad to look at it for you. but i also agree with the check bolts
NO BIKE AT THIS TIME
awesome I will check bolts for looseness............. no other noticeable wiggle other than at hard braking,,,,,,,,,,,,,, no vibration at all though.
SpyderLovers Sponsor
If these suggestions do not turn out to be the problem, check your A-Arm bushings.
red please stop saying wiggle, i love this site and don't want to be banished forever
I agree. My fender would move with my hand and the problem was a worn A-Arm bushing.
2013 RTS SE5
2013 Kawasaki Vulcan Nomad 1700
Took mine by the shop today for this very same problem except it was the left fender and there was no rhyme or reason to when it would vibrate. Hopefully the extended warranty will cover this repair
all fender bolts seem to be in order & no loose feel on the fender,,,,,,,,,,,,,,,,, just vibrates (NOT WIGGLES) hahaha very bad under hard braking, other than that you never see or feel it at all.
Redneck Diva
Member of the Southern Cruisers Riding Club Chapter #213--Central Georgia
Proud PGR rider
Disc brake gunk or warped. Possible tire balance
Can also be worn A-Arm bushing(s) as mentioned above.
That was my thought. I had a similar issue on the right side fender. I could move it by hand when I checked it and turns out I had some worn bushings in the A-Arm.
I just went thru this issue while on vacation, went to the dealer in Utah to have it checked, it was a warped rotor, fortunately this was under warranty
RT-S PE#0801
fender
I have seen that happen with a bad lower ball joint!!!!!!!
Front fender shaking
Hi I also have experienced front fenders shaking but not when braking. Mine sometimes shake when going down the road. I don't have alignment problems and the rt se5 doesn't vibrate anywhere else just the front fenders.
SHAKING ????
If there are no vibrations I would check the fender bracket bolts ASAP .......Mike
Thanks Mike for the heads up starting to notice at 42 to 45 miles per hour the right fender shakes but only on certain road conditions. Doesn't do it all the time. Also checked the tire pressure on both tires they are fine. When going down straight road I have even let go of handlebars and the spyder stays true. Not sure what else to check? Any thoughts
You need to look very close at this as mine and several others have cracked the tubing that is the bracket the tubing is very thin and vibrations cracked it
2 happy happy spyders
Fender Shake
Replace my rotors and brakes and the shake is gone. Ordered the rotors and brakes from Bajaron worked great.
