Results 1 to 20 of 20
    Nov 2014
    Whittier, CA
    Default Regular or premium fuel?
    I was told by my dealership to run premium fuel for better performance. Anyone have any thoughts?
    Jun 2010
    Las Vegas
    I have always run Premium in my Spyders.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Very Active Member Dudley's Avatar
    Dec 2008
    Jacumba, CA
    Read the Owners Manual and do what it says.
    2008 GS SE5 in 2008
    Traded at 43,000 miles for a left over
    2010 RT SM5 in 2011
    Traded at 57,000 for a left over
    2014 RTS SE6 in 2015, which has 35,000 miles
    Oct 19th, 2017, totaled 2014 RT while killing a Javaline
    Dec 12th, 2017 drove a 2017 F3L home. What an awesome machine!
    Never had any breakdown stranded issues.
    Premium works best for me. That is what I use/used in all my 's
    Default As it stands...!!
    you spent a pretty penny on your ryde you should give it the best. Higher octane, additives regardless of claims of more mpg or performance your difference is about a buck per tankfull...a buck..!! go on give her the best...
    ​2012 RS sm5
    Jun 2013
    queens ny
    93 and or above,,, no lower for me
    NO BIKE AT THIS TIME
    MOgang Member GloryRyders's Avatar
    Mar 2010
    St. Louis Mo.
    Another vote for Premium..........91 to 93 octane, whatever is available at the time!
    Spyder: 2011 RT Limited w/ RT-622 trailer
    Mods: ESI Brightsides, RT Rear Brightsides, HMT Brake Light, Scuff Guards, Utopia Backrest, Chrome, and more Chrome, Pearl White Rear View Mirrors, Rear Fender, and Dashboard, Black Rear Wheel and Belt Assy, SpyderPops Heat Shields & Bump Skid, Elka Stage 1+ Shocks, 2012 SF Graphics, Silver Carbonfiber Dash, Corbin Arm Rests, Baker A.W., BRP Vented WindShield. BR's Sway Bar, Tricled White Halo Lights, BadBoy Air Horn, Spyder Legs Floor Boards
    Active Member Commander's Avatar
    Jun 2014
    Southern New Jersey
    Premium for me, besides that is what is recommended in the manual
    I also run 93...
    However; nobody is going to come to your house and spray paint the windows, shave your dog, break your car's windshield, and start telling nasty rumors about you, if you run 87...
    All of the computerized stuff under the Tupperware will be perfectly happy to keep the engine from turning into a pile of molten debris...
    ...They just run better on the Good Stuff!
    Default RECOMMENDATIONS
    Quote Originally Posted by Commander View Post
    .....The same manual also recommends ......KENDA tires..........which I wouldn't use on my wheelbarrow ......just sayin.....Mike
    Feb 2015
    evansville, in
    Default fuel
    Quote Originally Posted by Hoagie View Post
    Premium for me
    2014 Spyder RS SM5
    RAM 5.7 HEMI 8 speed 4x4 crew cab
    They sort of HAVE to do that...
    Like it or not: Kenda and Vee are the only two manufacturers, that make tires "approved for motorcycle use", in the sizes that we need.
    I'm pretty sure that some Federal Commission somewhere, would go NUTZ, if they told us to use whatever we wanted!
    Invalid Emails
    May 2012
    Locust NC
    I try to run non-ethanol gas. Most times that's 93 octane but sometimes it's 89 octane. Both run well. My Om says I can run 87 octane.
    Nov 2012
    North Las Vegas, NV
    91 when available, but not afraid to use 87 when that's all I can get.
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
    For a 2012 RS; 87 is fine...
    That bike still has the 990 series engine, with the 10.8:1 compression ratio.
    The 991 series engines run a 12.2:1 squeeze on the fuel...
    Invalid Emails
    Feb 2013
    Castle Rock, Co.
    I have always run Premium in my ...jtpollock
    Very Active Member flaggerphil's Avatar
    Mar 2012
    Florida Space Coast
    Well, BRP and my dealer says premium is best for the bike so that's what I use. Mine does seem to run better that way.
    Phil
    I may be old, but I got to see all the cool bands.
    2011 Spyder RT-AC
    Default YOU CAN TRY THIS ALSO
    Quote Originally Posted by danlnc View Post
    To combat the ETHYL I use Marine " STARTRON " ( it's less expensive on-line ), and 87 octane my 1330 runs fine .......Mike
    Very Active Member robmorg's Avatar
    Oct 2013
    Pottstown, PA
    I also run 93...
    Shave your dog?
    Rob
    2013 RT Limited
    My "Mods & Farkles" Link
    May ALL your roads be beautiful
    Greisemer's Mill Bridge, Oley, PA
    2013 RT Limited , Lava Bronze with Antler Brown Seat
    We live in a scary World...
