Results 1 to 18 of 18
    Nov 2014
    canton, ma
    Default Bajaron sway bar install video 14 RT
    Is there a video? I can only find one for earlier models.
    Very Active Member finless's Avatar
    May 2013
    Stanton, ca
    Buy me a 14 and I will shoot one
    Kidding.....
    There is a 2013 sway bar video on Youtube as I recall. Should work for you.
    Bob
    2011 RT-S SM5 - Black
    Nov 2014
    canton, ma
    Unfortunately the instructions say it's different. Thanks anyway
    May 2013
    Stanton, ca
    I may be stupid but pretty sure it's the same.... If not, pretty dang sure it's 90% the same!
    Bob
    Nov 2014
    canton, ma
    I'll take a look.
    May 2013
    Stanton, ca
    The BIG difference between installing one on a 2010-2012 vs the 2013 and up....
    Is on the 2013 and up the bar is in a channel in the frame. This requires the Spyder to be jacked up much higher than 2010-2012 to get the bar out and back in.
    Other than that... any difference on how it bolts on, etc should be easy to follow.
    Bob
    Jun 2014
    Elko Nevada
    Default Sway Bar
    I just installed the BajaRon Sway Bar last week. took all of 45 minutes tops. The real key is to ensure you have your RT up high enough. At 22" it was a breeze. Hardest part was removing the tupperware and my highway pegs. If it wasn't for having to remove my highway pegs and then re-install them I suspect it would have been 30 minutes or so. And I had never done one before and had really no idea but once you get under your RT it's pretty self-explanatory.
    Very Active Member DriftersWay's Avatar
    Jun 2013
    Uniontown, Pa
    Quote Originally Posted by finless View Post
    Bob
    It different Bob. I installed both.
    The instructions are just a little tricky.
    I'll attempt a video after work to point out the bolts for you.
    2022 F3 Limited , Monolith Black / Dark
    Very Active Member mastertek2000's Avatar
    Mar 2012
    E Freetown MA
    you live in ma i am in freetown and can help you i have a shop at home just did mine i have done about 4 of them LOL
    Very Active Member bmwlarry's Avatar
    Mar 2012
    Beaverton, Oregon
    Sorry but not at all!!!
    Bob
    2015 an Am Spyder RT Limited
    2013 Yamaha WR250R - Sold
    2011 Can Am Spyder RT-S SE5 Limited - Sold
    2011 Aspen Sentry Trailer
    2003 BMW K1200LT - Sold
    2007 Unigo Trailer - Sold
    2001 BMW K1200LT - Sold
    2001 Honda 750 NightHawk - sold
    2015 RT Ltd , Canamspyderaccessories Brake pedal ext. Red
    May 2013
    Stanton, ca
    Quote Originally Posted by bmwlarry View Post
    Between the 13 and 14? What is so different?
    Bob
    Very Active Member bruiser's Avatar
    Eastern North Carolina
    One thing I found, there are two splash panels just below the links. They're very easy to remove and gives better access to the bolts on the heim joints. Install is slightly different than it was on our 2010 RTS.
    USAF '69-'89 E7
    Thailand/Vietnam 1972
    Member: Royal Order of Rat Bastards
    Bob
    The bar kits are identical and the actual bar install is also identical.
    The Tupperware, body parts and mount points are different because BRP moved the radiators between the 2013 and 2014/15 RT models. Moving the radiators makes the 2014/15 Bar Kit install easier.
    The 2013 RT is probably the most difficult of all models for the sway bar install. Not that it is all that hard. It just takes more steps to get at the bar and more time to do the install.
    Registered Users SarasotaSpyder's Avatar
    Apr 2015
    Sarasota, Florida
    How about install time on a F3?
    2015 Red F3 SE6 pending: better headlight bulbs, BR windshield, passenger backrest, Tricled safety lights and lighted bumpskid/ISP key holder....hopefully all by Biketoberfest.
    May 2013
    Stanton, ca
    Thanks Ron.... Thought I was going nuts there for a minute!
    Amazing how some folks spout inaccurate info with authority
    Bob
    Quote Originally Posted by SarasotaSpyder View Post
    The F3 is by far the easiest install of all with the exception of still needing to be lifted 18"~20". There is no Tupperware or other body parts to remove so you just do the bar swap and let it back down.
    Bob
    I don't expect that everyone will know all about each Sway Bar kit for every Spyder model. Like most things, there is more to it than a person may realize.
    I believe that all the information offered here is sincerely meant to help. When bad advise is given it is simply due to factors that the poster was unaware of.
    One reason I do not jump in on every thread about my products is that the information offered is usually very good. Since I can't really add anything to what a user is saying, I just sit back and marvel at the level of expertise available here on Spyderlovers.
    When I do attempt to set the record straight I hope I do it in a non-accusatory way. I never mean to call someone out.
    I'm glad that I stayed free of this one...
    Actually; I DID go poking around in Youtube, and I have been unable to locate a video showing the installation on a 2013 or later RT...
    Will somebody please buy finless Bob a bike??
