2014 rt sway bar install
Is there a video for installing a bajaron sway bar on a 14 RT? Im having a problem with identifying the location of some bolts in step 4 of the instructions. I could use a visual for orientation.
I sure wish there is one, let me know if you find one for the RTL (14)
SpyderLovers Sponsor
Step 4
14 RT:
pretty straightforward.
PM Baja Ron, but the only tricky part is the speednut that holds the bolt to the panels. Once that pesky bit is removed, it is all puppies and rainbows!
Joe Meyer
