AJ, that is a gear position sensor error and it usually happens when you come to a sudden stop. The computer isn't as fast as your braking, or in your case, as fast as your acceleration. As long as it goes away you are fine.
2014 RTL-SE6 8,600 miles
2011 RTS-SM5 5,000 miles
2010 RTS-SM5 59,148 miles
2010 RT- 622
Sounds like a gear position sensor hiccup. Could have been due to momentary confusion as to what gear the bike was in, corrected when you shifted gears. Others will likely weigh in with more comprehensive/detailed explanations, and with other possible causes.
MEP
2019 F3 Limited
Ooops..!!
that is the gear position sensor trying to tell you something that ain't so. Usually happens between gears on a soft shift but maybe gunning up put it in a position where it thinks you missed a gear. As long as it went out and no codes your fine.
2012 RS sm5
I guess I type faster than the other guys!
2010 RT- 622
When my Spyder gets hiccups
I try to scare it
If that don't work
I put it in a large paper bag
Now 2014 RT Limited Cognac
Was 2008 GS SM5
Don Garbarino
Cup Holder
GPS locking holder
Mud flap
Modified KNOTT grill
Phone holder and charger
Trailer hitch
Dual air horn
Auxiliary fuse box with relays
Heated clothing controller
volt/oil pressure gauge
Sequential signals in mirror
Tri Axis Handle bars
Baja Ron anti sway bar/heim links
shorty antenna
And many more
Thanks Ann and all!
Guess they must be using AMD chips and not Intel!
AJ
2014 RT-S
Akrapovic Exhaust & Cat Bypass
Bajaron Sway Bar w/links / Sena SM-10/Garmin 660
Comfort Seat w Adjustable Backrest
Decals by Purple Harley / Magic Strobe
Kuryakyn Black Widow Pegs Rivco Highway Brackets
Rivco Trunk Mounted Double Flag Holder
FOBO / Spyder Cuff / XM Radio w MC Antenna
I have seen that big E a number of times and asked a BRP technical guy at Spyderfest about it. I've only seen it when riding in ECO mode but he said that it is a warning that you are reaching the maximum revs for the particular gear you are in. If you ignore the E and continue to wind out the engine you will hit the rev limiter.
The malfunction indicator lamps list on pg 140 of my owner's guide says the gearbox position sensor malfunction big E is also accompanied by flashing N and R indicator lamps. It also appears to me, like Ann said, that sometimes my shifting may work faster than the ECM. JMO.
otherwise be a vulgar brawl.
Cognac 2014 RT-S
Sometimes I get the "Big E" also on my SM6. It happens to me when I put the bike into reverse, right after engaging reverse, when completely stopped with the engine at idle. I'll see the "E" until I start moving backward. Sometimes, not always.
I've only seen the green arrow in ECO mode, never the "E".
It seems to be little more than an inconvenience.
IBA #47122
2020 RT Limited Asphalt Grey
Same problem here...
..bike is currently in the shop for this error and about 6 other problems. About 1,200 miles on the Spyder. We'll see.....
Don
Did own: 2008, Red, SE5 - and 2010, Black, RT-S Premiere Edition Number 670
Now Own: 2014 Black RT-S SE6
Good luck; please let us know what they find!
Just an interesting observation on my part since I read this forum every day, but this is like the 5th person in the last 2 weeks that reported this same problem.
Possibly some BUDs code update recently? Or maybe a batch of bad switches? Something?
Not saying there is but I find it odd that since the 2014 came out I never saw this reported and now a bunch are cropping up.
Bob
2011 RT-S SM5 - Black
Bob
Bob, have most of these people said that they are getting the E while upshifting? I've never seen that myself, just on quick stops and I've never seen the flashing N and R accompanying it.
Maybe I need to do some jack rabbit starts to see if I can replicate what happened to AJ.
2010 RT- 622
Perhaps it's just the Nature of The Beast; it doesn't like extra fast upshifts or stops...
We haven't seen very many times, where it lead to anything more than the "E" showing up on the screen.
That's why i like this forum, when in need, or need help chime your need on this forum. A good place to start to solve a problem you may have.
2012 Spyder RT Limited Lava Bronze (Psalm 27:1;Luke 12:4,5)
I saw a flash of E the other day. I got in a hurry and my R to 1 shift was faster than usual. The only other place is at the gas station where after fillup, I want to get out of there. Not waiting until the has given permission (boot up process) to leave will show me an E if I want to shift into first to quickly.
There may be problems cropping up--since many have posted. My experiences with the E are self induced--IMO.
The computer likes to let us know just who is in charge sometimes.
12K miles and the second season of operation on my 2014 RT.
It has happened to me once also when I was accelerating quickly to avoid traffic. It was definitely hi-revs and quicker than normal attempt at shifting. I had always assumed it was just the computer telling me I was being a bad boy.
I haven't seen it since that one occurrence.
Same thing happened to me last week on my new 2014 RT-S SE6:
http://www.spyderlovers.com/forums/s...gear-indicator
Once I started to do a more positive shift instead of a quick hit of the paddle shifter, I no longer see the problem...
