Belt rubs plastic shield; found during jack-up. Check yours Now!
I found that after winterizing my Spyder and jacking up the rear the belt shield shows signs and sounds of rubbing the belt.
Enough that I will remove the shield and either re-mount it adjusted correctely or trim the shield as the belt must be free and clear or very very bad things can happen.
Check yours now!
