Results 1 to 4 of 4
    Jan 2013
    Barrie, Ontario. Canada
    Default 2 Questions. Vee Tire & Front Frunk Lid Adjustment
    2012 RTS SE5
    1- Does anyone have the Vee Tire on the back ? If so what pressure do you run in it?
    2- Is there any way of adjusting the front Frunk Lid so that it does not move while driving ?
    Thank you,
    Default HELP
    Quote Originally Posted by spydertrike View Post
    2012 RTS SE5
    Thank you,
    #1...Sorry I don't know, but wouldn't buy one ......# 2.....I have tried all sorts of adjustments and still couldn't get it to stop moving......so I just used some door weather strip foam ( the kind with adhesive backing ) on the upper corners and now it doesn't shake at all..........Mike
    Default Here you go..!!
    Vee tire is the same as kenda as far as tire pressure. Use the spyder recommended pressure and adjust as needed. As for the frunk lid BLUEKNIGHT911 gave you the solution...
    Gene and Ilana De Laney
    Mt. Helix, California
    ​2012 RS sm5
    Jun 2014
    ny
    tire brand never changes tire pressure on any type of vehicle, tire will tell you max pressure while vehicle
    will tell you running pressure.
