Results 1 to 11 of 11
Thread: Sway Bar
    Very Active Member DriftersWay's Avatar
    Jun 2013
    Uniontown, Pa
    Default Sway Bar
    I just installed my BajaRon Sway Bar. Took me 2 1/2 hrs.
    Just a short drive around the block and what a difference.
    Thanks Ron. You are the man.
    Butch
    2022 F3 Limited , Monolith Black / Dark
    Default Another happy customer...
    glad you got her done.. it does make a difference. Hope you get a longer ryde soon...
    ​2012 RS sm5
    Registered Users RBS66's Avatar
    Sep 2013
    PA
    Yes the bar is a noticeable difference right away. Great product and huge improvement.
    2013 RT SE5
    Bajaron sway bar
    Bajaron heim links
    laser alignment from dealer
    Inspector Gadget floor boards
    Smoothspyder belt tensioner
    Grip Puppies
    HEAT RECALL COMPLETED
    Very Active Member bmwlarry's Avatar
    Mar 2012
    Beaverton, Oregon
    I am all ready to start the install tomorrow!!
    2015 an Am Spyder RT Limited
    2013 Yamaha WR250R - Sold
    2011 Can Am Spyder RT-S SE5 Limited - Sold
    2011 Aspen Sentry Trailer
    2003 BMW K1200LT - Sold
    2007 Unigo Trailer - Sold
    2001 BMW K1200LT - Sold
    2001 Honda 750 NightHawk - sold
    2015 RT Ltd , Canamspyderaccessories Brake pedal ext. Red
    Aug 2007
    Greeneville, TN
    Quote Originally Posted by bmwlarry View Post
    Any relation to Rube Goldberg?
    Jun 2010
    Las Vegas
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Jun 2010
    Las Vegas
    I had to ask Joe who Rube was.
    2010 RT- 622
    Danbury Connecticut
    You're a brave man Larry.
    Be sure to post after you complete the job, if only to let us know you're still alive !
    IBA #47122
    2020 RT Limited Asphalt Grey
    Registered Users HVACR Guy's Avatar
    Mar 2015
    Oakville,Ontario Canada
    Default Duct tape
    If the women don't find you handsome, they should at least find you handy.
    May 2013
    fairless hills pa.
    Default add
    [Add his shoxk spring adjusters and you willl be real happyQUOTE=DriftersWay;972577]I just installed my BajaRon Sway Bar. Took me 2 1/2 hrs.
    Butch[/QUOTE]
    2014 rt-s black,bump skid,baja ron swaybar and shock spring adjusters,rivco highway mounts &pegs and trunk flag holders 2014 900 ace renegade
    New Palestine, Indiana
    Installed the BajaRon SwayBar yesterday. Not too hard to do. I bought a low-profile long reach 2 ton floor jack from Harbor Freight which slides under the 2014 RT without needing ramps or boards to drive on. I placed a piece of plywood on the jack bell to protect the frame and prevent sliding (metal-to-metal). I also bought a pair of rubber caps to put on the jack stands to protect the A-arm tubes. I raised the jack stands up under the A-arms every 2 inches or so as I jacked it up just for safety. I measured 19" (behind the sway bar) from the frame to the floor and stopped there and it was high enough to remove the old sway bar and install the new one. I also removed two screws that hold the plastic cover over the lower A-arms as the jack stands seemed to put some pressure on them.
