Results 1 to 5 of 5
    Very Active Member eddieshep999's Avatar
    Oct 2010
    Broadstone,Poole, Dorset, UK
    Default Locking Ram Mount
    I know many Spyder owners use Ram mounts to secure their equipment
    This information was posted to me by a UK Supplier - Not sure if it's available on your side of the pond, But it may well be worth
    investigating the part no maybe just the one used by the UK Supplier, So you may need to contact your usual Ram supplier for details
    If you use Ram Mounts, then you need this simple, cheap effective locking gizmo!
    RAM Anti-Tamper
    If you use RAM parts, you need this! Prevent easy removal of your Ram secured items using this fantastic (And Cheap!) mod from RAM:-)
    The RAP-S-KNOB3 consists of a 1/4"-20 female threaded security knob and key knob. The RAP-S-KNOB3 replaces all knobs on 1" diameter B size arms and mounts. It offers the ideal amount of leverage to properly tighten your mount to prevent slippage in heavy chop or in extreme vibration environments. With an emphasis on aesthetics and function, the RAP-S-KNOB3 is low in profile and only adds a small amount of additional bulk to your system when compared to the standard knob included. At a fraction of the cost of currently available keyed locking knobs, the additional peace of mind and tamper resistance comes at a very affordable price. The RAP-S-KNOB3 is the perfect accessory for keeping your mounted electronic device safe from theft and tampering.
    Eddie Sheppard
    Poole Dorset UK
    Get a Spyder - See the World
    Dec 2008
    Syracuse, NY
    I have the locking mechanism from RAM; but, it is a huge knob with a key lock. I like the one you've shown much better.
    Active Member whiteyron's Avatar
    Oct 2013
    Eden Prairie, MN
    Default Nice !!
    but seems it only protects the neck assembly. Most go-pro's, phones and gps clip on to the neck. When you remove them not much interest in the neck alone. This is a nice clean set up, does one patteren fit all..??
    Gene and Ilana De Laney
    Mt. Helix, California
    ​2012 RS sm5
    Very Active Member finless's Avatar
    May 2013
    Stanton, ca
    Not to be negative but trust me that if I wanted something sitting on a RAM mount, pretty sure with a good yank I can be off with it. If all the RAM parts were made of steal, then you might have something that cannot be ripped off.
    Bob
    2011 RT-S SM5 - Black
