Results 1 to 18 of 18
    Nov 2014
    Hudson Valley, New York
    Default Newbie question about lights?
    Folks,
    I've lit up everything I can find on the bike, and yet ONE of the circles in the headlights doesn't appear to do anything. I've hopefully attached a picture of what I am talking about.
    Any ideas here??? Do I need to get this back to the dealer to see why this isn't lighting? Also what are they/WHEN are they supposed to light up?
    Thanks,
    Jim
    Aug 2012
    Houston, TX
    that is as it should be
    I think in the UK they use those slots for the low beams, but not here in the states.
    Mar 2015
    forrest above Reno, Nv
    Red face A space for the rocket launcher??
    We must find a use for this space!!! Rocket launcher, twin 30 cal's, more turnsignals, running lights???
    Kaos
    2014 RTS , Circuit Yellow
    Default Well..!!
    you could always add lights there connecting to the park/running lights. or order the european set up which is better, they have less road lighting...
    They have you covered. As it should be is correct.
    Jun 2012
    Leavenworth, KS
    Quote Originally Posted by kaos View Post
    Kaos
    Need a Marvin the Martian disintegrator, otherwise there's just more junk to drive through.
    Mar 2015
    Default +1
    I like that idea!!!
    Kaos
    Feb 2013
    Northern California
    I asked this very same question as my first post here on SL about 2 years ago (and got the same answer about being on European use only). It was driving me nuts thinking that something on my Spyder was already broken when I just got it. Nice to see this blank spot bothers someone else too!
    Mod Monster Phil's Avatar
    Nov 2010
    Tyler, Texas
    That little thing is a small convex mirror on the USA RTs.
    You can add a small LED projection light (1 LED) to shine on to that mirror from down in the fog shroud. Not easy, but it can be done.
    ____________________________
    Phil - Tyler Texas
    2010 RT-Premiere Edition (Named DARTH) | Timeless Black | All My Mods--- ARE HERE | Phil. 4:4
    Vermont
    Quote Originally Posted by NorCalBud View Post
    I also have a 2014RTS-SE6 and the same area (blank Spot does not light up for me. Deanna
    Gremlin Bell
    SpyderPops Missing Guard Belt
    Ultimate F3 Floorboards
    Sway Bar with Links
    Rolo Laser Alignment
    Half Cover
    Show chrome Trunk Shock
    Vermont
    Quote Originally Posted by Phil View Post
    Can a dealer add a small LED projection light( 1 LED)? Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
    Nov 2010
    Tyler, Texas
    Deanna- depends on the dealer. I'm not trying to be trite, but my dealer... absolutely not. But I'm sure there are some that might be able to tackle it.
    Phil - Tyler Texas
    Dec 2010
    Telford, UK
    Quote Originally Posted by revjvegas View Post
    Nope, I ride a UK-spec RT and I can tell you for sure they're NOT our low beams. I doubt they serve any purpose at all, other than to create speculation among Spyder riders as to why they are there!
    Dec 2010
    Telford, UK
    One LED on its own would just about light up a small room in a doll's house. Just about.
    Nov 2010
    Tyler, Texas
    Quote Originally Posted by GeoffCee View Post
    Oh Geoff.... with the right LED and a little bit of lens focusing..... it'll light up the entire fog light shiny bits!
    Phil - Tyler Texas
    Default ONE LED
    ......I believe the new OEM LED headlites ( for various vehicles ) are a single LED chip.........Mike
    Dec 2010
    Telford, UK
    Phil, thanks for the info! I fitted left and right LED's to my RT's dash to make my turn signals more visible (to me) - they're a huge improvement over the dim hard-to-see stock item but even so they're not so bright as to dazzle me at night. It was my experience of those LED's I had in mind.
    I should have remembered that I have also mounted a pair of LED daylight running lamps on my RT and they are very bright indeed but each lamp is illuminated by 4 CREE LED's, each one having its own reflector to throw its output forward. Used in a doll's house they would prolly give a dolly sunburn!
    Nov 2010
    Tyler, Texas
    HA!!! So true!!
    Phil - Tyler Texas
