Results 1 to 19 of 19
    Very Active Member OverHillAndDale's Avatar
    Sep 2014
    United States
    Default Another non-BRP trailer woe
    For those of you who will simply say "Get a BRP trailer", well the $ just weren't there.
    For the record, I'm not the one who started this thread but I'm having my own non-BRP trailer woes.
    I purchased a used Aluma motorcycle trailer a couple of weeks ago. Nearly all the lights are LED, although I think the license plate light might be incandescent. The lights all work if I connect them to a 12 volt sources, but if I connect my Spyder to them only some of the lights work.
    Not sure, but I'm thinking the Can-Am harness just doesn't supply enough current for the running lights (the brake and turn signal lights fail when I connect the running lights, which include the possibly incandescent license plate bulb). So here are what I believe my options are:
    - Find a way to get inside the small dome-shaped license plate light, confirm that the bulb is incandescent, remove it if it is, retest. Or
    - Wire a relay to provide 12V battery power to the running light. This would involve splicing into the harness somewhere and a bunch of other nasty stuff.
    So, has anyone got experience routing a wire from the frunk back to under the seat where I'd have to splice in?
    Does this sound reasonable or is there a better choice?
    Would I be better to just buy the Big Bike Parts harness that people sound like they're having better luck with?
    You guys (and gals) are usually really helpful, so I'm counting on your expertise once again.
    2020- RT Limited
    Chalk White, Can-Am rear passenger armrests, Comfort Seat, Grip puppies, RAM Cup Holders, Providence RAM Mount
    FOBO2 TPMS
    Aluma MCTXL trailer
    BRP hitch
    Big Bike Parts wiring harness
    Permanent Smile!!!
    Jul 2011
    Mitchell, Ontario, Canada
    BRP uses a Hopkins 5 to 4 fully isolated converter. I just looked on the Hopkins web site and that module is capable of 8 amps for each output line. So if your trailer is using more than 8 amps on the running lights and most of them are leds that trailer should be bright enough to blind someone. That almost as much power as your headlights use.
    2018 F3 LIMITED
    Sep 2014
    United States
    This is very confusing ... the trailer lights work fine when I hook them up to a battery but start failing when I hook them up to the bike. Yes, I've confirmed the grounding of the trailer circuitry to the white wire.
    Anyone else use an Aluma trailer with the BRP trailer harness?
    2020- RT Limited
    FOBO2 TPMS
    Aluma MCTXL trailer
    BRP hitch
    Permanent Smile!!!
    Oct 2013
    Wood Village OR
    Thats what happed to both our trailers , and when we stopped in Bend Or. the tech changed out the module with on from Uhaul and they work perfectly 6 months and many many miles later. I don't know what it was with the BRP module but they both went out after about a week .
    2014 RTL , Black Currant
    Sep 2014
    United States
    Dang frustrating. More than the $ is just the effort of tearing into the bike and putting it back together. All the wiring harnesses on motorcycles have very short leads and are hard to get.
    However, the more I look at the trailer the more I'm convinced that all its wiring is good. I went ahead and ordered a BBP harness that will be here on Saturday and if I can't get this working I'll remove the BRP harness and install the BBP harness.
    My trailer would like 5 wires anyway, so it might be better in the long run.
    2020- RT Limited
    FOBO2 TPMS
    Aluma MCTXL trailer
    BRP hitch
    Permanent Smile!!!
    May 2014
    Courtenay,BC,Canada
    Default auto module
    Quote Originally Posted by easysuper View Post
    Same here. I bought the cheapest convertor module from the local auto parts store and spliced the inputs to the l turn, r turn,brake,tail lights and the ground onto the braided ground strap located under the seat. The lights all work on the trailer as a test. I haven't gone anywhere or had them on for very long yet so that will be the next test. I also downloaded the service manual and got the color codes for the above input wires.
    Bob
    Oct 2015
    Cumming, Ga
    Default Aluma trailer
    Quote Originally Posted by OverHillAndDale View Post
    I am going through the same thing right now. Dealer told me that I need to self ground the trailer or I would continue to blow out the module.
    happy old fart stillriding's Avatar
    Apr 2010
    Elyria, OH
    Quote Originally Posted by JayD View Post
    I don't have an Aluma, but I had the same problem. When my dealer installed my THIRD module I had them ground both the module to the frame and the trailer to itself. These were suggestions provided by Spyderlovers members on this site. No problems since.
    Nov 2013
    Oro Valley Arizona
    Never had any of these problems with my BRP RT-622 trailer.
    OUCH-sorry Just saying. I know they are expensive but for
    the most part trouble free with reasonable maintenance. At my age a little more money for a lot less grief works pretty darn well.
    Sorry your having all those problems.
    Jack
    2015 BMW R1200R LC
    2014 RTL SE6 Pearl White
    2012 RT-622 trailer viper red
    2011 Polaris Ranger green
    2016 Can Am Maverick
    Jan 2016
    PA
    I'm only blue skying here, I haven't done it but why not try this
    Opto isolator
    Bossier LoUiSiAna
    Quote Originally Posted by stillriding View Post
    No way we will be able to test but this many reports sure sounds like BRP found a way to electrically proprietary żż
    This will go beyond the trailers & into other farkles
    2013 STL SE5 BLACK CURRANT
    SpyderPop's: LED bumpskid
    minispyder dash toy
    Lid lox
    KradelLock
    Pakitrack
    FLO (Frunk Lid Organizer)
    BRP fog lights, trailer hitch
    SENA 20S EVO
    Jan 2016
    PA
    I doubt if there is any witchcraft involved.
    Jun 2010
    Las Vegas
    Quote Originally Posted by jaherbst View Post
    Jack
    It happened to me with my 2010 RT-622 trailer when hooked up to my 14 RT. The wiring harness was changed and it doesn't get along well with others. I blew two modules before BRP completely rewired my trailer and added the new grounding wires.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Bossier LoUiSiAna
    Quote Originally Posted by spyderCodes View Post
    Me too but some complicated enginering is right up their ally
    minispyder dash toy
    Lid lox
    KradelLock
    Pakitrack
    SENA 20S EVO
    Jun 2015
    Hobart, IN.
    Default Trailer Lights
    I would make sure you have a very good ground, even if you have to run a separate wire..............
    Jun 2010
    Waukee, IA
    I use an Aluma Trailer with the BRP wiring and have used it on two different bikes without any difficulty. Dealer installed for me on both bikes and used the wiring diagram that came with the Trailer.
    Wolfee
    Idaho
    All trailer wiring connectors have a pin for ground. That should tell you something, as in run a ground from every light back to the trailer plug and to the towing vehicle ground lead. I have never seen dependable grounding of trailer lights using the trailer frame and hitch connection.
    2014 Copper RTS
    Oct 2015
    Cumming, Ga
    Default Wiring Harness
    Quote Originally Posted by OverHillAndDale;96itself.800
    I had the same problem with my aluma. I had toground the trailer to itself.
    Jan 2015
    Colorado
    Default No problems with a Lumina trailer
    Jack
    Not all non-BRP trailers are cursed. Just finished a 4000 mile trip with lots of pouring rain using a Lumina trailer. No problems, no leaks, pulled easy. I did caulk the seams when I first got it and added additional weather stripping to the opening but other than that just routine bearing greasing.
