GloRyder
Was just looking at GloRyder lights do they still connect to wheel the same as old model?
2015 RTSE, Red Pearl, Shorty Antenna, Chrome Rear Rack, Deer Whistles, BajaRon Anti-sway Bar
I have only had the latest model, so cannot confirm if the same.
But I can tell you the install was super easy.
Pop the plastic OEM cover off, then insert the mounting ring and secure with the two set screws.
Then screw the unit to the mounting ring.
That was pretty much it.
2016 RT-S Special Series
The older ones might have had a 3 set-screw attachment...
The new ones have a simpler set-up.
About 15min install first time.
2015 RT-S
2015 SE6 RT-S
Black/Red Special Edition.
