Results 1 to 8 of 8
    Very Active Member 900Dave's Avatar
    Jun 2013
    Fleetwood, PA
    Default Poor radio reception
    I find that the radio reception is very poor on my Spyder. I can only get one station that is clear and a couple others that are in and out. In my truck I can get a lot of stations to come in clear in my area. Anyone else have this problem? Has anyone tried an antenna booster?
    2016 Spyder F3 Limited Steel Black Metallic
    Lamonster approved LED Headlights
    Lamonsters LED Fog lights
    BRP Driver & Passenger backrest
    BRP Trailer Hitch
    Shamrock Black & Polished
    Signature light
    Elka front shock's
    Rolo Laser Alignment
    Dual Power outlets
    Garmin 590 GPS
    Jul 2011
    Mitchell, Ontario, Canada
    Just a thought. I seem to remember some RT folks with bad reception because of too much thread locker on the base of the antenna.
    The reception on mine is not as good as my Ford Escape, but close.
    2018 F3 LIMITED
    As posted above, a thread locker check might be in order.
    Jun 2013
    Fleetwood, PA
    Default I would of never thought
    Just wire brushed all the thread locker off. My favorite station was almost all static the other day out in front of my garage under clear sky's. Today after removing the thread locker it was crystal clear inside the garage which is partly under ground. I will have to get out for a ride tomarrow and give it a try.
    Thanks for the tip.
    BRP Trailer Hitch
    Signature light
    Elka front shock's
    Dual Power outlets
    Garmin 590 GPS
    western Colorado
    Quote Originally Posted by 900Dave View Post
    Thanks for the tip.
    thats good but make sure the antenna is really snug or else it maybe Mia later
    Very Active Member dlby's Avatar
    Nov 2014
    Indiana
    Get a bluetooth interface for about 15$
    Then use your smartphone free app (Spotify, Pandora, etc)
    Connect it via FM bluetooth device to your radio.
    If you do this you will never go back---
    I was old school & did not know what to do without fm,cd,tape etc
    But as the Blues Brothers once said
    I see The Light!
    No offence at all if you dont like my suggestion
    Just so much music at your fingertips. Im talking 1000s of songs makes am fm commercials a thing of the past
    Jun 2013
    Fleetwood, PA
    Quote Originally Posted by dlby View Post
    I see The Light!
    When on longer rides I stream IHeart radio via bluetooth to our Sena headsets. But when I ride locally I just grab my other helmet and turn on my favorite fm station.
    BRP Trailer Hitch
    Signature light
    Elka front shock's
    Dual Power outlets
    Garmin 590 GPS
    Nov 2014
    Indiana
    Gotcha--
    Enjoy the Ryde
