08 GS SM5 Shifting Problem
16K Miles
Out of Warranty
I got on my spyder by stepping on the shifter instead of the foot rest. By the time I realized what I was doing the damaged was done. The shifter sink about a inch or two down. The engine was off and the clutch was not engaged at the time
Now shifting is tough. It goes from N, 2, 3, 4 and 5 but I can't shift into 1 or R. Unless I keep shifting up and down and I will find 1st or R by luck. It does not want to shift down. Sometimes shifting from higher gear to lower gear is tough too.
Sometimes the gear selector shows "E"
Any ideals?
Bent shift rod?
UPDATE
UPDATE
UPDATE
My Shifter Mechanism Is Bent
Reason: Update
you need to take the shift lever off the siftshaft to start. Straighten the shift lever back. Hook it back on and shift back and forth or up and down to free the shaft finding "N". Re-position the shift lever and tighten it down. Remove the key and walk away for a spell. This allows the computers to reset. Return and turn on the ignition for a minute then start her up and try the gears. Hope this gets you going and only the splines got a bit twisted...
Gene and Ilana De Laney Mt. Helix, California
2012 RS sm5
16K Miles
Out of Warranty
Any ideals?
Bent shift rod?
Check your reverse cable adjustment and Gearbox Position Sensor. That's usual problem with the SM5.
x 2.
