Page 1 of 2 12 LastLast
Results 1 to 25 of 27
Thread: Fox Rear Shock
    Registered Users 1blackbeauty's Avatar
    Apr 2015
    northern ontario
    Default Fox Rear Shock
    Came in today. Hope it works as good as it looks.
    Default Good luck..!!
    let us know how it turns out. Fox makes a good shock so you should have great results...
    ​2012 RS sm5
    Very Active Member one2doo's Avatar
    Oct 2007
    Johnson City TN
    I put one on mine works great took all the slop and sponginess out recommend
    Mar 2015
    US
    I almost went with the fox upgrade but I called them and they told me it came with the same weight spring as the OEM Sachs... I no experience with Elka but I ended up buying the stage two from them...
    just curious, on the Fox, there does the resevour mount? I wanted that option from Elka but their mounting for the hyd preload and resevour sucked so I went with the stage 2 with manual adjusted preload and a custom dual rate spring. Bad part is the are running 3-4 weeks behind on orders
    mark
    Bullies are sad pathetic People
    Mar 2013
    Oz
    Default feedback will be welcomed
    I'm thinking of upgrading the rear on my ST, not too keen on having no preload at all, especially when towing our little camper. Look forward to your "full and comprehensive" report ... I presume this is the Fox through BRP ? Thanks in advance.
    Apr 2015
    northern ontario
    I will install it and post pics later today. Yes this is the BRP shock and the res mounts to the frame tube just above the brake pedal. Having preloae adjustability is a very important part of shock setup and tuning. My factory shock fades and rides like crap after 20 miles or so. Stock rear shock is a joke.
    Sep 2008
    TX
    The Fox rides nice. Adjustable spring preload and damping controls. Compared to our ST Ltd , the ride is firm but not harsh. Handles the rough roads very well - no pogo sticking over the mogouls. Plus it looks cool.
    Wayne
    pauly1 - SpyderDeb's 'wrench'
    2018 F3-T & 2015 F3-S Road Warrior Foundation Tribute customs
    IBA #48220 SS1000 BB1500
    2015 F3-S , OEM na Basic Black with Custom Wrap
    Apr 2015
    northern ontario
    Just finished the install and went out for a short run, way plusher than the stocker and no harsh hits either. I left the settings as they came and will set it up for my weight later. Looks awesome also. Oh yeah, shock body is huge. 57mm or 2 1/4 inch.
    Mar 2015
    US
    Quote Originally Posted by 1blackbeauty View Post
    Had the Elka mounted its reserve like that I would have gone with the stage 4. They designed a crappy looking mount that attaches under the passanger grab handles and attach with what looks like big hose clamps
    Can't wait I shed the factory shock... According to fox the Stock and their shock both had a 360lb spring. Not nearly enough for the average guy, weight of the unit, accessories, and gear
    mark
    Very Active Member hawkiii's Avatar
    Apr 2008
    Northern California
    Is this the upgraded Shock that BRP offers or is this direct from Fox? I need to do something, two up riding needs help.
    Very Happy Spyder Guy
    The 2015 F3 has over 46,000 miles
    Have Spyder...Will Travel
    Apr 2015
    northern ontario
    Quote Originally Posted by Nyparrothead View Post
    mark
    Pretty easy to change a spring if need be. I just went for a rip with my son on the back (400lbs between us), rides awesome. Stock shock bottomed on everything, this one does not.
    Apr 2015
    northern ontario
    Quote Originally Posted by hawkiii View Post
    Yes it is.
    Apr 2008
    Northern California
    Yes it is.
    Thanks. Have a great day.
    Mar 2015
    O.c california
    Default elka mounting parts looks realy crap
    I always prefer elka but stage five and four shocks mounting parts realy looks crap especially the metal parts that hang on to the seat , may be its just for showing how it will bolt on. may be they will produce beter and specific design for the f3
    Registered Users Ronbo's Avatar
    Mar 2013
    Arkansas
    Default Rear shock
    Is that the unit that runs about $900?
    thanks,
    Ron
    Active Member llyrad's Avatar
    Edmonton, Alberta Canada
    Default Spring
    Can you give some info on this spring you installed? Where did you get it, part number, price, etc? And how tough was it to install? I think upgrading the spring is the way to go as well.
    Apr 2015
    northern ontario
    Quote Originally Posted by llyrad View Post
    Im just using the spring that cam with it, check with Fox for optional springs (I would think they will offer some). Removing the spring is easy, remove shock, back off pre-load adjuster till spring retainer is free, remove retainer, remove spring.
    Apr 2015
    northern ontario
    Quote Originally Posted by Ronbo View Post
    thanks,
    Ron
    Yes it is.
    Nov 2014
    Alexandria, VA
    Default Fox Rear Schock
    Do I need to remove the belt to remove and install a new Fox rear Shock? I ask because I had my laser alignment done and the belt is aligned correctly. I do not want the dealer to remove the belt and I start having belt vibration issues again.
    Thanks.
    2016 Spyder F3 Limited, black, Special Edition, SE6, belt tensioner, Bajaron swaybar, AKARAPOVIC, F4 windshield with vent. Previous 2015 RTS in black and 2011 RT Limited, SE5 with Bajaron Swaybar and Bumpskid
    Sep 2008
    TX
    No need to remove belt to install shock.
    Wayne
    Very Active Member hypurone's Avatar
    Jun 2016
    NorCal - Northbay
    It will, ask me I how know!
    Chuck
    Active Member _..stiffler..'s Avatar
    Feb 2015
    NB Canada
    I have pictures and a whole explanation of how to replace rear shock in another post.
    Sent on Note 5 in Taptalk
    2011 RT Limited , White
    Sep 2013
    Johnson, Vermont
    Is it just me or does it seem crazy that a person has to spend $900 to get a decent performance ride out of their rear suspension? I mean these bikes aren't cheap. Shouldn't they come better equipped with more capable components from the factory?
    Feb 2015
    NB Canada
    Nature of toys. They come with shocks that are good enough. Not the best.
    Nov 2014
    Alexandria, VA
    Quote Originally Posted by hypurone View Post
    It will what, remove the shock or ask you how?
