Results 1 to 17 of 17
    Jun 2014
    People's Republic of NY
    Default Reading the dip stick
    Any tips on reading that gray dip stick.
    is there an after market easyer to read replacement.
    right now I'm using the touch n smear method
    thanks
    committee for postings
    If you lay the dipstick down across a piece of tissue paper; enough oil transfer over, that you can see where it came to on the stick...
    Just make sure to get any paper pieces off of the stick, before putting things back together.
    Default Don't know..!!
    I use the angle to the light and read where the oil shines...our dips are flat black so the oil is fairly easy to see cause it is glossy... don't know of any aftermarket ones...
    ​2012 RS sm5
    Active Member TEHelms's Avatar
    Sep 2014
    Indian Trail, NC
    Default the dip stick..
    Quote Originally Posted by vided View Post
    thanks
    Just had to laugh because I have the same issue. I'm considering painting the thing white or red or ANYTHING BUT DARK!
    Jun 2014
    Thanks
    i like the old tissue paper trick
    will give a try
    Very Active Member ottawa-rider's Avatar
    Sep 2012
    Casselman, Ontario, Canada
    I use the best tool Mother Nature provided.
    The tip of a finger ....... to feel exactly where the oil line is.
    2018 RT LTD , Black
    Default WHAT I DID
    I had a strip of the plastic binding material they use to hold heavy packages together......it's flat , about 3/8 in wide and fairly stiff , but still flexible .....I measured off about 16 inches and marked it longer than the OEM oil dipstick......this way I know before hand when it starts to be near the ADD mark....Since it is wide and white it shows off even new oil....................just a thought................If you are coming to Spyderfest ....PM me and I'll bring you one .............Mike
    Jun 2014
    Thanks for the info.
    spyderfest is not in the cards, but thank you for the offer.
    Invalid Emails
    Mar 2012
    Gore,Quebec,Canada
    Drill a small hole in the upper (full) and add marks, the oil should fill the holes when checking! I intend to do this as I also find it difficult to read.
    2012 RT , stock Lava Bronze
    Jun 2014
    Quote Originally Posted by Netminder View Post
    thanks
    Active Member viperryder's Avatar
    Oct 2011
    Ohio
    Default Red line
    thanks
    Some one in the past asked this same problem. His reply was to take a red magic marker and put a line down the center of the dip stick. This will allow you to see the oil level better.
    2014 RTS SE6 , Cognac
    Mar 2015
    forrest above Reno, Nv
    Thumbs up File
    I also had a difficult ( impossible ) reading of new oil on the dip sitck. I took a small file and filed 3 "rings" around the round dipstick to devide the measuring space into 4 spaces. easy to do--easy to read.
    Kaos
    2014 RTS , Circuit Yellow
    I don't know if I'd drill holes, or take a file to it...
    Being such the Klutz that I am; I want it to be as sturdy as possible.
    Sep 2014
    Indian Trail, NC
    Default Reading the dipstick
    I dipped mine in yellow plasti dip...seems to work fine.
    Invalid Emails
    Mar 2012
    Gore,Quebec,Canada
    Bob, not talking a 1/4 inch hole here! Maybe a 1/16 or 1/32(might be to small) just enough for the oil to sit in the hole. I do not think that would weaken it much? Unless you do not pay much attention when checking your oil and ram it in the hole, which I think would leave the possibility of breaking it holes or not. JMHO! If the vided is worried there are some other great suggestions above.
    I never thought that you'd punch a hole that large; I just know what sort of carnage I'm capable of!
    Invalid Emails
    Mar 2012
    Gore,Quebec,Canada
    Come on Bob, I am sure like me, you are not an expert, but have all the necessary tools to do what needs to be done? . My motto is if I do not feel confident before starting a job, I consult an expert, which luckily we have many on this site!
