Results 1 to 6 of 6
Thread: hard steering
    san jose ca
    Default hard steering
    Hi all looking for comments/help...took the 2011 RSS and the 2014 STL out for a long ride yesterday, the first in a while. After about 50 miles of curvy mountain roads my wife said her shoulders and arms were very tired. Her first real ride since open heart surgery 3 months ago I figured it was just fatigue. I swapped bikes with her as the RSS has always been a little easier to steer. OMG the woman is strong is all I can say, coming back from Sana Cruz to San Jose on hw 17 is a lot of high speed sweepers and it took way way more strength than I remember too drive this thing!!!! Gotta be something with the power steering but I have no idea what too check. Yes still under warranty but my local dealer stopped carrying them and hoping there's something simple I can check before having too travel too far. Help plz
    Default IT SOUNDS LIKE
    In the early models there was a recall on the power steering DPS ......Yours may be a fluke , but that is what it sounds like.......There is no power steering fluid ---- it's an electric motor.................and it's good it's still under warranty because it's expensive ...over $1000............Go to any dealer .....Mike
    Mar 2015
    NE Kansas
    It may be too simplistic a question, and I dont mean to offend you, but did you check theair pressure in the tires? Poor tire pressure can dramatically affect handling.
    Feb 2013
    Grand Rapids, Michigan
    Default Hard Steering
    Check battery connections check battery could be bad. The DPS takes alot power. This happen to me changed the battery and all was well.
    As posted above, tire pressures can make a big difference. The easiest route, sometimes is the answer. Hope it is not DPS issues.
    san jose ca
    Default thanks all
    Ok I did the old kick the tire check before posting the above.....guess my foot needs calibration. Checked with a gauge and a whopping 11 psi in each front tire !!! Now at 20 and a half each it once again steers fine 😁
