Results 1 to 21 of 21
    Nov 2014
    Whittier, CA
    Default Shifting problem on 2012 Limited RT
    All of a sudden I can't get the bike to shift into the gears and the paddle seems looser. Worked fine at first today then I can't get it past 3rd gear. RPM's ar staying high when it goes back to 1st gear on downshift. Help please!
    Take a look at the shift linkages...
    ...They're down sort of underneath where you'd be changing the oil...
    (Underneath the bike; of course)
    Perhaps something has come loose?
    Default Few things to check...
    Start with the oil level. Then the shift arm /linkage. Then the paddle shifter. Need to see if your getting any codes indicating shift sensor faults. Hope you tried the key walk in case of a glitch. Looking more like a paddle problem from the change in the feel of it...
    ​2012 RS sm5
    It does sound like shift linkage. Had the same symptoms when it happened to me one time.
    Nov 2014
    Whittier, CA
    Default re:shifting problem
    Is it an easy fix?
    Nov 2014
    Whittier, CA
    I tried another ride and now can't get past 1st gear! Goes into 1st and reverse with no problems
    Have you taken a look under the bike yet?
    (We can't tell you what you're going to see; you need to do some eyeballin' for us...)
    Quote Originally Posted by Hoagie View Post
    Is it an easy fix?
    Just reattach with screw/nut.
    Nov 2014
    Whittier, CA
    Default Problem resolved.....
    Took the Spyder to the dealership. They hooked it up to diagnostics. Couldn't find a problem. Tech took the bike out and said it shifted fine. Then I tried and took the rpms up higher and it shifted. BUT, then I also noticed the Cruise control was switched on. When I turned it off the bike shifted like before. I felt like an idiot but also found out something new. I wonder why they didn't know that the cruise control was a factor? Anyway, thanks to all who tried to help! Happy riding folks! John
    I am not sure if cruise control has any effect on the shifting process. If you are running cruise control and shift either up or down, the cruise control will disengage. Cruise control on should not effect your ability to shift though.
    I always leave cruise control on--on both 's. That way I am ready to kick it in whenever I want to. I live rural, so the highway is always a quarter mile away.
    Nov 2014
    Whittier, CA
    I am not sure if cruise control has any effect on the shifting process. If you are running cruise control and shift either up or down, the cruise control will disengage. Cruise control on should not effect your ability to shift though. I always leave cruise control on--on both 's. That way I am ready to kick it in whenever I want to. I live rural, so the highway is always a quarter mile away.
    I don't have an answer for whether it does or not, but as soon as I disengaged it , I was able to shift at lower rpms again. Too many side streets around here to be gunning it way up in order to shift. Anyway, I am thankful it wasn't a mechanical problem...labor at the shop is $119 an hour! lol
    Glad to hear that you found the problem.
    It sounds as if you may have been just trying to shift a bit too early... it happens!!
    Generally speaking; the 998-equipped bikes with the SE-5 transmission, like to be shifted at up around 5000 rpm or so.
    It allows the clutch to be fully engaged; no slippage means much longer clutch life!
    Jul 2011
    Mitchell, Ontario, Canada
    Having the cruise control on should not have cause any of the symptoms you have described. Another possibility based on your description of how you drive at very low rpm's it is possible it was in trailer mode. it forces higher rpm shifts.
    2018 F3 LIMITED
    Nov 2014
    Whittier, CA
    Definitely not in trailer mode. I check the settings often because it seems the auto volume likes to go off. I like it set at medium.
    Nov 2014
    Whittier, CA
    Glad to hear that you found the problem. It sounds as if you may have been just trying to shift a bit too early... it happens!! Generally speaking; the 998-equipped bikes with the SE-5 transmission, like to be shifted at up around 5000 rpm or so.It allows the clutch to be fully engaged; no slippage means much longer clutch life!
    There are times I like to get on it a bit to get away from heavier traffic. lol I used to have a Honda VTX 1800 which had a lot of power. Just seemed strange to me that being in cruise control mode would affect the shifting. Maybe try it and see if it affects the way it shifts for u?
    Jun 2013
    LeClaire, IA
    Just ran into the issue the other day on my wife's 2011 RT-S. Tech said it has to be at least 3500 rpm to shift. They didn't charge me anything because I apparently amuse them from time to time.
    Jul 2011
    If you are loosing your radio settings it is because when you turn your key off and then turn it back on before it fully shuts down, for example when you forget to set the parking brake, some or all of your user setting will return to default. Settings that I have noticed will change are: Display of radio on main screen, auto volume, bass, treble and few others I can't think of at the moment.
    2018 F3 LIMITED
    Nov 2014
    Whittier, CA
    Thumbs up
    Yes, I have done this when forgetting to set the brake. Thanks for that information! I will make sure I set the brake first now.
    May 2015
    San Antonio Tx
    Default Shifting Problem
    I'm currently experiencing the same problem and I thought it was a fuel flow problem, but when I took it to the shop and spoke with the lead mechanic he told me that it was a throttle linkage problem! That there are 5 computer on the bike and if one isn't communicating correctly with the others it throws them all off. I toll him that the only way I could get the bike to go into gear is if I retard the throttle, that's when he told me it's not fuel control it's throttle linkage going bad! I hope that helps you and gets you back on the road. I hope to be back on the road next week after I get my bike out of the shop.
    2021 F3T-LTD , Light Blue
    Dec 2014
    S.E. Michigan
    Quote Originally Posted by LeClaireRog View Post
    Apparently we go to the same shop.
    ~Sandee~
    ~Sandee~
    2016 RT-L (Purchased used in February 2018)
    RT Dash Mount (from JT's Spyder Store)
    Kuryakin Trident Highway Pegs
    Hopnel Pouch
    Magic Mirrors
    Spyderpops Foam Handgrips
    Iron Butt #35273
    Girls on Spyders #2779
    Oct 2014
    Masterton NZ
    We just struck a similar problem with our 2010RT, my Wife and I were heading out on a 5hr road trip and got 100m up the road when my Wife exclaimed she couldn't change the gears!!
    It wasn't linkages it was the small springs in the Paddle shift, they had virtually disintegrated, these springs are about 6-7mm long and as I don't live close to a Can Am dealer I bought the smallest spring I could from an Auto parts shop; the spring was 15mm so I cut it in half and replaced the broken ones. Careful if you take the shifter apart it has small ball bearings which fly everywhere!! A couple of trial and error with getting the length correct and it now works better than before.So off we went on trip a few hours late. ON journey we stopped at a Can Am dealer and enquired about getting the correct springs and we were told they (BRP) don't sell them separately you have to buy the complete shifter which costs aprox $NZ1000.00 the springs I got cost $NZ5.00
