Results 1 to 22 of 22
Thread: HID on ST?
    Very Active Member ARCTIC's Avatar
    May 2012
    IOWA
    Default HID on ST?
    I guess I'm a glutton for punishment and am considering putting HID light kit on my ST limited. My RS wouldn't run with the xenon depot kit. Has anyone had any issues with error codes or rough engine idle or any other strange gremlins once converted to HID? How easy was the installation?
    2017 Chevrolet Camaro SS convertible. 2017 GMC Sierra cc diesel. 2017 Arctic cat RR 137 ES
    Mar 2012
    NJ
    Ooof......I thought I'd never, ever, read this from you. After everything on the RS.....hope you have better luck on the ST.
    Sep 2013
    Houston
    I'd suggest the new led lamps. You will not have the troubles and they are instant on
    Blue Flame Spyder F3-S
    2015 F3S , Blue Flame
    May 2012
    IOWA
    Quote Originally Posted by DrewNJ View Post
    It hasn't happened yet. I love the way the HID light everything up and my RS spoiled me. I even put HID on my truck after riding that thing a few thousand miles and being amazed at how well they lit up the countryside
    Funny you mention this. .. I have a led kit sitting at my house waiting to be installed in my snowmobile. Are they are as good as HID or significantly better than halogen?
    Mar 2012
    NJ
    Halogen vs LED vs HID is a huge topic on the HD boards. Especially since HD has an OEM LED add on headlight. Concensus seems to be that LED is brighter/better than halogen but not as bright as HID. However, LED is able to keep a good beam pattern where aftermarket HID lights in a non projector housing makes that really bright non focused scatter beam most oncoming traffic doesn't care to see.
    LED lights seem like they would be a nice upgrade. Wonder about heat though???
    May 2012
    IOWA
    I installed the LED lights in my snowmobile and they are okay(ish) I'm uncertain if they are any brighter than the halogen bulbs. I have 2 sleds side by side and when I start them and shine the light on the garage door in the dark they just appear different not one better than the other. Evidently the high power LED's don't like heat at all because they have fans built into them. I was disappointed with the mounting tabs on the LED light kit as they were plastic!!!! If I do decide to do the spyder lights I'm putting a morimoto bixenon kit in. We'll see.
    May 2012
    IOWA
    To those wondering about LED lights vs. Halogen. I just got a chance to get 2 of my sleds out in the dark to compare and adjust the newly installed LED lights.
    My arctic cat snowmobile takes the same H4 bulb as the spyder so it's a very good comparison. Take a look for yourself and make your own conclusions:
    LED headlights:
    Factory H4 lights:
    Mar 2012
    NJ
    I think those LEDs look quite good!
    May 2012
    IOWA
    The nice thing about LED is that you don't have to worry about the bixenon extra BS.
    I might get my truck out and youtube HID lights for comparison. I REALLY want to install these on my spyder but not sure if I should take the chance: http://www.theretrofitsource.com/hid...l#.VSHz0I7F_ju
    May 2012
    IOWA
    Ok.. that didn't take long. I've kinda turned into a light freak.
    My 2015 GMC 2500HD with morimoto 35W HID headlights.
    Sep 2013
    Houston
    Take a look at the Phillips leds fron xenon depot. Much different from others on the market. Flex heat sinks instead of fans and beam patterns that actually work in projector housings like the spyder.
    Nov 2013
    Alliston,Ontario
    Default HID on ST
    Quote Originally Posted by ARCTIC View Post
    I put them on my ST limited and used the HID error canceller and it prevents throwing error codes and the bike runs great, Used H4 Bi Xeon kit and it looks really good.
    May 2012
    IOWA
    Quote Originally Posted by Kevin Nemeth View Post
    not familiar with the error canceling kit. Does the bixenon keep the bulbs hot when switching from high to low so you don't get the dim light?
    Sep 2013
    Houston
    It moves the bulb position to re-aim the light pattern rather than using 2 lamps.
    May 2012
    IOWA
    That is interesting. Looks like the bixenon kits require another box to perform the "dimming" function. Wonder how much room there actually is to hide all that stuff
    Sep 2013
    Houston
    While not impossible, its not easy and hense why I suggested the LED replacements from XenonDepot. I have the HIDs in my bike, installed over a year ago and the LEDs installed in my wifes bike. Not much difference in the results and each has minor pluses and minuses, but the ease of install goes to the LEDs by a wide margin.
    Active Member Just Doo Me's Avatar
    Aug 2008
    Millbrook,Ontario
    Default heat
    How is the heat from the led vs. the hid ? Any worries about the plastic lenses melting in the headlights? I had hids in my 08 GS but it had the glass lens in the headlights so no problems.
    May 2012
    IOWA
    Quote Originally Posted by Just Doo Me View Post
    The heat is almost non-existant
    Sep 2013
    Houston
    The LEDs use less power than the HID which uses less power than the oem halogens. No problems with any of the three options with heat.
    May 2012
    IOWA
    You actually think the LED is nearly as bright as the HID? The Philips bulbs you mentioned aren't even rated very high compared to other kits out there. I see 3,800 lumens frequently advertised and the Philips are 3,000 ?
    Sep 2013
    Houston
    Yes, lumens of light that bounce around inside the projector housing and just create heat are useless. The Phillips units that XenonDepot sells are the first ones I have encountered with proper beam pattern to work correctly in a projector lense housing.
    The HIDs are a wee bit brighter overall but have far more light scatter. The LEDs are more focused and whither and come on instantly.
    May 2012
    IOWA
    I don't have projector light housings in my headlights
