Excesisve heat from right side of RT
During Bike Week in Daytona I noticed a very hot situation coming from the radiator exhaust port on the right side of my 2011 Viper Red RT ! We were in some traffic but, I was wearing shorts ( 92 deg. ) ! I saw on this site where someone designed a plastic cover for the port ! Would this adaption make the spyder run HOT in warm weather ? If someone could direct me to the conversion cover, I would appreciate it, very much ! Thank you !!!!!
Banged Up Member
Hi John. I don't mean to sound like a smart ass (although I very well may be), but I typed in "excessive heat RT" in the search feature above, and found 9 pages of previous posts dealing with this issue.
I'm responding this way because it would take an inordinate amount of time to adequately answer your question. I mean no ill will. I'm simply trying to help you and at the same time be brief.
Chris
Spyderpops sells the Block Off plate www.spyderpops.com
if you do it correctly it will send the heat under the bike and out the back.
Shorts on any motorcycle , is never a good idea.
Cruzr Joe
Originally Posted by Cruzr Joe
... Shorts on any motorcycle , is never a good idea.
Cruzr Joe
commando is also not a good idea...
Two things...
wearing the proper gear will help alot. And as mentioned spyderpops (sponsor on the home page) has heat management systems to deal with this. There are many many threads and posts on how to deal with the heat.
2012 RS sm5
Have to Agree
We routinely ryde in temps above 90 degrees and I always wear vented textile ryding pants. The fact of the matter is, not only is it not safe to ryde in shorts, but you expose your feet and legs to the heat generated by the engine. In fact you will stay cooler with ryding pants on, and you will be less likely to suffer from dehydration. The more skin Yiu have exposed to the sun and heat the faster Yiu loose water. So to stay safe, and more comfortable cover up, drink lots of water, and add some evaporative cooling tools such as a cooling vets etc.
Heat is always a big concern coming out the radiator port. But that being said I work in shorts and often ride to work in them. Never long rides from home. There are many ideas to help with the heat from the furnace hole.
Sold my 14 RTS went back to 2 wheels.
2014 Kawasaki Vaquero SE
I too wear shorts, but they are underneath an armored mesh riding suit. ATGATT
All the great movements in the world began with a cup of coffee!
2018 F3-T
My mods: Can am Trailer hitch, USB and 12 volt power outlets, Gustason windshield, Bead rider seat cushion, battery harness for electric gear and battery tender, Time out trailer.
I've seen the block-off plate modified with an exhaust pipe turndown, that directs the heated air away from the rider...
That night be worth looking into!
2014 Copper RTS
2016 F3 Limited
2019 Ryker Rally
2014 Suzuki V Strom 650
2020 CSC TT 250
Thank You
Just ordered the Block off plate from spyderpops ! Than you very much, I have been looking for a solution to the heat problem since Daytona. By the way it was 98 degs. in Daytona the day I wore shorts !
Cruzr Joe
It's above 95 where I live most of the summer and I never wear shorts.
Bill C.
2014 right grille trimmed to fit earlier models cost $25. The gear police can take a break he did not ask for your clothing opinions.
2013 Mag Silver SE5 RT BahaRon Sway bar & Sway bar links, Grip Puppies, Kuryakyn Helmet locks , Ultimate Seat w/Utopia Backrest, Dash power outlet, Spyderpops BumpSkid, Swagman Cup holders, Full size Brake Pedal, Seal DLX Floorboards, Freeway Blaster horns, Sylvania Super Bright fender LEDs, Scotchlite 680 Rear & Fender Reflectors, BRP Fog Light Kit, LED Mirror turn signal strips, 2014 RT grille mod. Outlaw Laser Alignment
