Results 1 to 16 of 16
    Jan 2013
    San Diego area
    Default JT's breather kit with cat bypass
    I just installed JT's air filter today took 4 hours, 3 knuckles and I now understand why everything is so expensive when the dealer does the work. It was the first time I've taken off the tupperware what a job. While I had it down I also installed Baja Ron's spark plugs and wires to make it time well spent. It tested well and tomorrow I'll take a longer ryde. All in all the changes in the last month this and the cat bypass have made the ryde respond a lot differently.
    Loving the RYDE
    Nov 2012
    North Las Vegas, NV
    Getting that airbox out is a job!
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
    Registered Users yamahog's Avatar
    Jun 2012
    Vernon Texas
    Default All ears
    I did the JT's air filter and am loving it so far, not too loud for me, but nice deep throaty sound.plugs and plug wires will be a breeze now.I am considering the cat bypass, keep up the review.
    Ram mount on both upper air deflectors custom ram mount for ATC9k action cam
    Chrome Dear Whistles
    Dual Color MagicFLEX® Channelz finder lights
    TIPZ units
    CAN AM SPYDER RT RADIATOR UPPER BLOCK OFF PLATE
    CAN AM SPYDER RT RADIATOR LOWER BLOCK OFF PLATE
    CATALYTIC CONVERTER SHIELD
    TITANIUM EXHAUST WRAP
    JT's AIR FILTER KIT
    Jan 2013
    San Diego area
    Default Airbox
    At one point I considered a cutoff saw
    Loving the RYDE
    Nov 2012
    North Las Vegas, NV
    I didn't change to the JT air filter, I put a K&N in the stock air box and did the plugs and wires from Bajaron, front and rear brakes and changed the anti freeze. I joke that it took 5 minutes to change the rear plug and 5 hours to do the front one.
    2016 F3 Limited
    2019 Ryker Rally
    2020 CSC TT 250
    Default Here's the thing..!!
    The next time you need to get up under there it will be a breeze. The first time is always a bear but after that your a pro and you will question the shop rates...trust me..!!
    ​2012 RS sm5
    Registered Users Dragonrider's Avatar
    Feb 2009
    Canby, OR
    Now run non-ETOH gas for a couple of tanks, and the milage will impress....
    2014 RT SE6 Rider
    X - Honda Rider
    X - RT S driver
    X - RS driver
    Lifetime VFW Member
    Sep 2013
    Houston
    Quote Originally Posted by Dragonrider View Post
    If only that were an option....
    Blue Flame Spyder F3-S
    2015 F3S , Blue Flame
    Apr 2013
    South Carolina and Florida
    Quote Originally Posted by bzbaeren View Post
    I used a Rotozip!
    2013 RTS SE5
    2013 Kawasaki Vulcan Nomad 1700
    Jun 2010
    Harpers Ferry, WV
    I'm thinking about installing JT's filter kit on my wife's '11 RT.
    Two questions:
    1) OEM air cleaner housings are designed to limit intake noise. With the foam pre-filter over the paper element, is the JT kit significantly louder?
    2) I've read the manual on accessing the air box. What panels really have to come off ?
    Sep 2013
    Houston
    Quote Originally Posted by millers1 View Post
    Two questions:
    I think even with the foam prefilter there is a BIT more noise. But its not offensive at all.
    Remove the frunk and body panels down both sides. That is the easiest part of the job.....
    Jun 2010
    Harpers Ferry, WV
    Thanks JC.
    Very Active Member ahh-cool's Avatar
    Jun 2014
    south florida
    I did
    Jan 2013
    San Diego area
    Been riding it this way for a while now and LOVIN it the MPG have picked up some but I love the growl around 4500 RPM also feels snappier. Hard work to do your self all the upper ware on both sides off and the Frunk as well, glad I didn't try to do it without taking it all off it would have been very hard. Only took about 21/2 hours and two knuckles of skin all in all well worth it.
    Loving the RYDE
    Very Active Member jthornton's Avatar
    Feb 2013
    Poplar Bluff, MO
    Two questions:
    Pistonblown has a good picture video of installing on a RS... same but different than the RT.
    http://www.spyderlovers.com/forums/s...tock-filter%29
    JT
    May 2013
    Stanton, ca
    Quote Originally Posted by jthornton View Post
    JT
    JT, if you twist my arm and let me try it (as I may not want to keep it if I don't like it), I will shoot a video on doing it on a RT
    Bob
    2011 RT-S SM5 - Black
